oil drain, bung
Old Aug 29, 2005 | 10:37 PM
integra3586's Avatar
Default oil drain, bung
does any one know where to get a bung welded on an oil drain for a vortech supercharger, in the phoenix area? the install manual doesnt say i need to weld on a bung rather taper the oil pan with a center punch, then use a tap
Old Aug 29, 2005 | 10:50 PM
Cray91's Avatar
you should be fine just drilling the pan and tapping it. I would suggest putting a nut on the fitting on the other side of the pan, rather than just relying on the threads you put in the pan. The wall is pretty thin.
a good alternative to welding if you don't have a welder.
STN_Pat
Nov 29, 2012 04:05 AM
JdmMidWest
Feb 20, 2012 05:20 PM
Stewie
Welding / Fabrication
Nov 9, 2005 08:38 AM
fandango
Jan 20, 2005 06:20 PM
