oil dipstick
Old Jul 1, 2002 | 12:21 AM
B18C4-T's Avatar
Default oil dipstick
I just put my Drag3 in Saturday. I have a B18c and the oil dipstick won't fit between the manifold and the manifold bolt. I cut the dipstick off and put it in from the bottom to seal the tube, but can't check my oil. Does anyone have any ideas? Is there an aftermarket dipstick that will fit in there?
Old Jul 1, 2002 | 12:31 AM
qwkteg125's Avatar
Default Re: oil dipstick (B18C4-T)
umm buy a new dipstick. it will fit but needs bending & for some people a slight shave of the rubber piece.
Old Jul 1, 2002 | 02:13 AM
Ri5e's Avatar
Default Re: oil dipstick (qwkteg125)
Find a big metal rod, stick it in the oil dip stick hole and try to bend the oil dip stick thing ... it's pretty strong.
Old Jul 1, 2002 | 06:41 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: oil dipstick (BG Boost)
Ooh...my friend did that and snapped the oil dipstick tube.
On mine, I just trimmed off a little of the rubber on one side.
Old Jul 1, 2002 | 06:51 AM
PrecisionH23a's Avatar
you need to get that fixed asap, when running a turbo checking your oil everyday should become a common practice.
Old Jul 1, 2002 | 06:56 AM
CovertFI's Avatar
Default Re: oil dipstick (GudeH23a)
if i dont see oil leaking i dont check. checking everyday is kinda extream huh?
Old Jul 1, 2002 | 07:28 AM
int3gra's Avatar
Default Re: oil dipstick (CovertFI)
checking oil everyday is as extreme as changing your plugs every oil change!!
Old Jul 1, 2002 | 06:02 PM
Default Re: oil dipstick (int3gra)
well when you run high boost your engine consumes a lot more oil... I run around 15psi and have a fully built motor, i usually check under the hood at least every day or 2 to make sure everything looks ok and all my fluids are where they need to be and what not. And yes i do have a cardboard mat under my car to easily identify if i ever do leak oil or any other fluids. And yes i am obsessed
Old Jul 1, 2002 | 11:56 PM
SIK IN DA HED's Avatar
New User
what he said.
EGgoJDM
Dec 1, 2009 12:05 PM
"Ridge"Racer
Honda Civic (2006 - 2015)
Aug 8, 2007 05:22 PM
mickey513
Feb 14, 2003 08:46 PM
