oil in charge pipes
Old Mar 20, 2009 | 06:54 AM
Blue-EM1's Avatar
Default oil in charge pipes
i did a search and it seems there is supposed to be a little in there but i mean when i pull the pipe off by the intercooler enough is in there what it poors out and is being blown out threw the BOV. i was told it could be the oil return? is that possible or is that too much and the turbo is blow. its a drag kit so it has that gay *** fixed/welded return line.
Old Mar 20, 2009 | 08:14 AM
jfoster's Avatar
Default Re: oil in charge pipes
Oil seals in the turbo are likely dead. It needs a rebuild or replaced.
About the return, if its not a nice down hill shot to the pan... and the oil sits in the turbo is gonna push past the seals.
Old Mar 21, 2009 | 12:43 PM
Blue-EM1's Avatar
so could the seals still be good, just the oil pushed passed or once the oil pushes threw its done? and also how much is a rebuild
Old Mar 22, 2009 | 04:21 AM
laziebun's Avatar
If the oil can pass through the seal then the seals arent doing it job and need to replace. So to andswer your question the seals are no good. I think a full rebuild is like 300 i could be wrong. GL!
marcj
Oct 6, 2008 12:16 PM
Toanz
Aug 31, 2006 06:49 PM
Blue-EM1
Nov 29, 2005 05:23 PM
Blue-EM1
Nov 20, 2005 07:23 AM
dirtySOHC's
Apr 3, 2003 05:37 PM
