Oil catch can on FI SOHC?
Old Aug 1, 2002 | 10:11 PM
Pengo's Avatar
Default Oil catch can on FI SOHC?
anyone running an FI sohc using an oil catch can. if so, have you actually noticed any oil being collected in there? or is it a waste of money? thanks
-alan
Old Aug 1, 2002 | 10:56 PM
Smashback's Avatar
Default Re: Oil catch can on FI SOHC? (Pengo)
Oil will get caught, but not a lot. I admit, I'm running the breather filter, but it's always better to run a hose to the intake so the crankcase fumes are evacuated by suction.
Old Aug 2, 2002 | 01:56 AM
ion_four's Avatar
Default Re: Oil catch can on FI SOHC? (mplex2000)
Will this still be much of a benefit when positive pressure will be present in the intake, ie. boost? I guess it depends on how boost-happy you are
Old May 19, 2003 | 10:51 PM
psileepR's Avatar
New User
Default Re: Oil catch can on FI SOHC? (ion_four)
Bump... is it worth it for D16 Turbo guys to run a catch can? i know oil vapors will lower the octane rating and the can hopefully reduces it... but is it worth it for us SOHC guys?
Old May 19, 2003 | 11:21 PM
Pritos's Avatar
New User
Default Re: Oil catch can on FI SOHC? (Civtek)
if it reduces the chance of detonation no matter how small, go for it. Even if we're sohcs. Depending on the condition of your motor, for some it'll help alot, for others a little.
Old May 20, 2003 | 01:37 AM
ion_four's Avatar
Default Re: Oil catch can on FI SOHC? (Pritos)
what the hell does having a sohc motor have to do with this?
In any case...you hook up the catch can to the pcv and the intake, NOT THE CHARGE PIPE, so there is no boost, only vac.->atmospheric.
Old May 20, 2003 | 03:01 AM
Pritos's Avatar
New User
Yep, the application is the same for a sohc or dohc so there isn't a need to differentiate the two. pcv -> can -> pre-turbo
Old May 20, 2003 | 06:27 AM
kommon_sense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ion_four &raquo;</TD></TR><TR><TD CLASS="quote">what the hell does having a sohc motor have to do with this?
In any case...you hook up the catch can to the pcv and the intake, NOT THE CHARGE PIPE, so there is no boost, only vac.-&gt;atmospheric.</TD></TR></TABLE>
exactly
Old May 26, 2003 | 08:06 AM
TommyV's Avatar
Default Re: Oil catch can on FI SOHC? (kommon_sense)
FYI, I am running SOHC FI, and after about 9K... I pulled off the intake pipe going in to the turbo.. there is a **** load of oil.. well enough to blow some into the intake charge which as we all know helps to promote detonation...
A catch can is necessity on all built cars FI OR NOT - In my opinion.
BEYAAAH
Aug 23, 2006 08:05 AM
ilovemyb16a
Aug 11, 2006 12:21 AM
hatchedzex
May 24, 2004 07:30 PM
Drew Peacock
Mar 15, 2003 09:54 AM
Troy
Jan 4, 2003 10:12 PM
