Oil in Blow off.
Old Aug 6, 2007 | 12:26 AM
MikeyD98's Avatar
Default Oil in Blow off.
I'm ready for some bad news, so tell me exactly how bad it's going to be.
Old Aug 6, 2007 | 12:49 AM
bb_one's Avatar
Default Re: Oil in Blow off. (MikeyD98)
If there is oil in your charge pipes, chances are your turbo seals are shot.
Old Aug 6, 2007 | 06:19 AM
MikeyD98's Avatar
Default Re: Oil in Blow off. (bb_one)
So I'm guessing new seals and i should be good?
Old Aug 6, 2007 | 08:13 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
get a rebuild kit for your turbo, and get the chra rebalanced as long as you have it apart.
Old Aug 6, 2007 | 08:52 AM
1995Civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeyD98 &raquo;</TD></TR><TR><TD CLASS="quote">So I'm guessing new seals and i should be good?</TD></TR></TABLE>
Yes sir.
What turbo do you have?
Old Aug 6, 2007 | 09:00 PM
MikeyD98's Avatar
Default Re: Oil in Blow off. (1995Civic)
Garrett T28
Old Aug 6, 2007 | 09:21 PM
1995Civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeyD98 &raquo;</TD></TR><TR><TD CLASS="quote">Garrett T28</TD></TR></TABLE>
Did you buy this turbo brand new?
Garrett's are Notorious for having their seals go bad very quickly
Old Aug 6, 2007 | 10:12 PM
MikeyD98's Avatar
Surprisingly, I bought it used against my better judgment, but I've had it on for almost 30k and this was the first thing that went bad.
Old Aug 7, 2007 | 12:48 AM
ahmongboi's Avatar
i thought that if there's only little oil in your charge pipe then thats normal for turbo cars thats the intercooler pipe right. because there's for mine i can't see the oil but you can tell that it's kinda moisture of oil in the intercooler piping.
Old Aug 7, 2007 | 07:53 AM
1995Civic's Avatar
Default Re: Oil in Blow off. (ahmongboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ahmongboi &raquo;</TD></TR><TR><TD CLASS="quote">i thought that if there's only little oil in your charge pipe then thats normal for turbo cars thats the intercooler pipe right. because there's for mine i can't see the oil but you can tell that it's kinda moisture of oil in the intercooler piping.</TD></TR></TABLE>
Not that i know of.
When the inner seals on your turbo go bad, the oil goes into your intercooler and charge pipes, bov, and can lead into you intake manifold as well. Once it does that then you're fucked
Old Aug 7, 2007 | 10:00 PM
MikeyD98's Avatar
There wasn't just a little bit. I saw a nice cloud of brown mist when I shifted 2nd to 3rd. Of course, I immediately pulled over and had my cousin come pick up the car, and it hasn't been started since. I'm currently in Iraq and saving some money for an H22A4 swap.
Old Aug 8, 2007 | 05:50 AM
HiProfile's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1995Civic &raquo;</TD></TR><TR><TD CLASS="quote">Garrett's are Notorious for having their seals go bad very quickly </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeyD98 &raquo;</TD></TR><TR><TD CLASS="quote">Surprisingly, I bought it used against my better judgment, but I've had it on for almost 30k and this was the first thing that went bad.</TD></TR></TABLE>
Lol, thats like saying stock trannies are weak...when the same 700whp honda w/n00b driver has broken 10 in a row.
Use the turbo wrong, and **** happens. Hondas are known for high oil pressure, and w/o the proper restrictor, that will beat on your seals. Garretts are some of the most used turbos on Hondas, and Hondas are definately the most NA cars that get an aftermarket turbo (no provisions for low-pressure turbo oil supply). Coincidence?
I've used older turbos, but I run a restrictor. I've never seen oil in my pipes (aside from the wd40 I spray in initially), and definately not in my BOV. I kinda wish I did, since my greddy is starting to corrode inside from being so oil-free.
BTW 30k on a turbo isn't bad. Some of the new turbo Mazdas with turbos crap out at 10k
EX-T
Jan 18, 2008 08:44 AM
2000civic ex
Jul 10, 2007 07:35 PM
hatchinprogress
Oct 31, 2005 06:15 PM
speedemon
Aug 11, 2004 05:49 PM
shotty527
Oct 10, 2003 10:53 AM
