oil on #2 plug !!!
Old Jun 20, 2003 | 08:19 PM
88crxvtec's Avatar
Default oil on #2 plug !!!
just got the rex running today, took it out about 3 times and didn't notice any smoke pooring out. When I got home my brother told me to check the plugs to see if its running rich or not. When I pulled the #2 wire the boot was soaked, then when I pulled the plug the plug had oil all over the top and bottom.
I'm hoping to find that the spark plug seal is bad, I seem to remember oil pooled on top of the plug before I pulled it because I was cussing. the boot was so swelled with oil it came apart in the tube and was a Bioutch to come out. Guess I'll run a compression test tomorrow. But since oil is on both sides and earth has gravity there is a good chance its a seal right? all the other plugs were ok....
b16
DSM 450 + Hack + 255lp
running .45 bar
Tial wastegate
Old Jun 20, 2003 | 08:22 PM
VTgringo's Avatar
Default Re: oil on #2 plug !!! (88crxvtec)
I had that same problem on my crx zc about a month ago. i just bought a new valve cover seal set with the rubber spark plug seals. slapped them in and haven't had a problem since
Old Jun 20, 2003 | 08:25 PM
VTgringo's Avatar
but then again i ran a compression check right after i did that and came up with 160, 155, 140 and 155. the 140 being the cylinder with the oil on the plug. these numbers were with low compression pistions too.
Old Jun 20, 2003 | 09:26 PM
88crxvtec's Avatar
well i'll do a test tomorrow wish me luck
Old Jun 21, 2003 | 05:12 AM
88crxvtec's Avatar
Default Re: (88crxvtec)
well good news! 180 compression (cheep autozone checker) so it looks like bad o rings....whew!!!!
Hope the parts dept is open on saturday!
VTEC_Du_Ma_Mai
Sep 5, 2008 01:41 PM
superslow-oto
Jul 7, 2008 06:52 PM
Pandahatch
Sep 14, 2005 08:13 AM
gixxer6
Oct 29, 2002 01:10 PM
KekeK-18
Aug 15, 2001 05:16 PM
