Oh screw me....literally. :(
Old Jul 29, 2002 | 02:07 PM
HXMan's Avatar
Default Oh screw me....literally. :(
Found out the cause of the clanking noise my engine was making. Took off the flywheel inspection plate and look what fell out.
Guess what, its a ****** pressure plate bolt. Fixing this means tranny has to come off.....I HATE removing and installing trannies too!!!
Can I drive for a while missing one??!!
Old Jul 29, 2002 | 02:14 PM
niedejb's Avatar
Default Re: Oh screw me....literally. :( (HXMan)
You could drive while missing one but how do you know others arent loose?
Old Jul 29, 2002 | 02:15 PM
accordking's Avatar
Hey don't worry. I've tightened pressure plate bolts by removing the starter and with a little skill you can tighten all the bolts. Putting a bolt in is something I have never done. But, should work though.
Old Jul 29, 2002 | 02:16 PM
ceemarun's Avatar
what signs pointed you out to look there?
Old Jul 29, 2002 | 03:32 PM
HXMan's Avatar
Default Re: Oh screw me....literally. :( (accordking)
AWESOME!!!! Best news I heard all day!!
Oh, I thought about looking there because the noise seemed to be coming from my tranny area. I thought the starter was hanging up on the flywheel or something.
Old Jul 29, 2002 | 04:38 PM
Mase's Avatar
Im sorry man, i like triple checked the torque on those bolts when i changed out my clutch and resurfaced my flywheel...how long has it been since you changed out your clutch? in other words, did the bolt come loose right away, or has it been awhile? makes me nervous still that could happen to me. Good luck getting it back in
Old Jul 29, 2002 | 06:13 PM
HXMan's Avatar
Default Re: Oh screw me....literally. :( (CDooMe2)
I installed a clutchnet stage 2 clutch about 2 months ago. I thought I had them torqued properly but I guess not.
Old Jul 29, 2002 | 07:02 PM
bruthaboost's Avatar
I torqued mine to according to the helms and they backed out on me. I had to drop the tranny to figure this out. I used some threadlocker and 5 more ftlbs and no probs yet kind of (through out bearingis squealing,but thats unrelated). Accordking is right on about tightening them up through the starter hole-it's way easier than the alternative.
Old Jul 29, 2002 | 07:26 PM
paulzy's Avatar
you can put some grease on the head of the bolt to hold it into the socket
Old Jul 29, 2002 | 08:50 PM
SIK IN DA HED's Avatar
New User
Default Re: Oh screw me....literally. :( (Slow_ass_4dr)
daym, its gonna be a pain in the *** to get into the tranny again... for one bolt.
Old Jul 30, 2002 | 06:30 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: Oh screw me....literally. :( (dlplayboy)
I don't torque mine, I let a little 3/8" impact do the job.
About 30-35 ft/lbs when it gets done.
Old Jul 30, 2002 | 01:20 PM
HXMan's Avatar
Default Re: Oh screw me....literally. :( (Mista Bone)
I ordered a new ICM and the pressure plate bolts today. I will probably replace the missing bolt this weekend.
Gizmo
Honda Motorcycles
55
May 14, 2007 03:09 AM
ludesleep
Apr 4, 2003 03:41 PM
infamousALLMTR
Nov 14, 2002 11:46 AM
Carlo
Nov 10, 2002 11:21 AM
