odd smoking issue
Old Dec 21, 2006 | 09:36 PM
EdsGTI's Avatar
Default odd smoking issue
The car started to do this today, if its a cold start (about 30-40F here) It will smoke thick white smoke, its not normal cold start smoke, much thicker.
Then once it warms up or even during warm up i can blip the throttle and it dumps blue smoke out. When driving its not a lot of smoke if any, but if im in 3rd gear on the highway run it up to 6grand and let it decel it starts to smoke a little. Once i roll back onto the throttle it puffs out fast.
I havent done a comp test yet, the car is an absolute ape, 18psi spins 3rd gear. Im jsut not sure where to look, i saw some residual build up on a few of the intake valve stems when i had the intake mani off working on it, but didnt pay too much mind. From your past experiences what have you seen? Valve stem seals, turbo seals (gt series, gt3076r, less then 5k miles on the CHRA) or rings? I have been spinning it to 7500+ daily (no more then 8200 but ive been rather hard on it lately)
Old Dec 22, 2006 | 07:16 PM
wshondaman's Avatar
Default Re: odd smoking issue (EdsGTI)
sounds to me like you have a turbo problem. my car was doing the same thing just before the seals blew out completely and i started loosing hellacious amounts of oil. check the exhaust side of the turbo outlet and look for oil buildup. good luck
Old Dec 23, 2006 | 06:58 AM
PrecisionH23a's Avatar
How is your oil return ran?
Old Dec 23, 2006 | 07:00 AM
DaveF's Avatar
Default Re: odd smoking issue (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">How is your oil return ran?</TD></TR></TABLE>
hopefully its uphill from the turbo to the pan, those work the best keeps the turbo nice and lubricated
Old Dec 25, 2006 | 03:58 PM
EdsGTI's Avatar
Default Re: odd smoking issue (dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">hopefully its uphill from the turbo to the pan, those work the best keeps the turbo nice and lubricated </TD></TR></TABLE>
yeah ur funny.
here is the cross post with the info.
https://honda-tech.com/zerothread?id=1846184
prettylew
45
Dec 16, 2007 06:48 PM
xcellorator
Jun 8, 2006 02:41 PM
Boost2NA
Dec 24, 2003 10:32 AM
