Odd Breaking up problem???
Old Oct 24, 2004 | 05:29 PM
  #26
DOHCarp's Avatar
Default Re: Odd Breaking up problem??? (Universal Magnetic)
I tried the V-tec thing and it didn't work
but thanks for the help..any other ideas?
Old Oct 24, 2004 | 07:02 PM
  #27
m R g S r's Avatar
Default Re: Odd Breaking up problem??? (DOHCarp)
So you know it's in the ignition then. .
I guess the stock system isn't strong enough, and the MSD you have is fucked?Are you on the second MSD box, or you said new 6al because you purchased it new and threw it in?
If you only tried one MSD box, that may be your problem.
Old Oct 24, 2004 | 08:04 PM
  #28
DOHCarp's Avatar
Default Re: Odd Breaking up problem??? (m R g S r)
I tried two brand new MSD boxes and both had the same result.....now I put a new coil in along with the MSD box and it ran the same...so my coil was deffinatly bad, but didn't solve my problem
so I think the MSD box is actually ok.
Old Oct 25, 2004 | 08:43 AM
  #29
Universal Magnetic's Avatar
what fuel pump are you running and do you have proper voltage going to it under load? Try monitoring fuel pressure and see what it does when the break up happens. Both of those cars that had this break up problem i went ahead and wired relays to supply the pumps with 12v...The problem also could be the vtec crossover point might not be in the right spot. Or, is cam timing straight up? Are you running the enough ignition advance in the hondata? Hope this helps.
Jeff@torquefreaks.com
Old Oct 25, 2004 | 03:03 PM
  #30
DOHCarp's Avatar
im useing a walbro intank, but with factory wireing. the fuel pressure stays up when it starts to break up and the fuel pump is at good voltage.
IM going to pull my tranny to see if I can find out my my VSS keeps getting chewed up...maybe that will help.
Old Oct 30, 2004 | 10:51 PM
  #31
Adi Radoncic's Avatar
On Fire!
Are u using a msd ss blaster coil or a stock coil?
tripple check and quadruple check your wiring and make sure you don't have any grounds where there isn't supposed to be any.
Old Oct 31, 2004 | 03:20 AM
  #32
djvtec5's Avatar
im having the same problem but going into boost can someone help me out heres my thread sorry to jack yours lol https://honda-tech.com/zerothread?id=1040554
Old Oct 31, 2004 | 01:38 PM
  #33
DOHCarp's Avatar
Default Re: Odd Breaking up problem??? (newgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newgsr &raquo;</TD></TR><TR><TD CLASS="quote">Are u using a msd ss blaster coil or a stock coil?
tripple check and quadruple check your wiring and make sure you don't have any grounds where there isn't supposed to be any.</TD></TR></TABLE>
I am useing an MSD blaster coil. I have just redid all my grounds and made sure that all wireing is correct.....I am still ahving the exact same problem...is there anyone near me that I can just take this thing to. Its killing me having this car here and not being able to use its potential.
Old Oct 31, 2004 | 01:56 PM
  #34
pissedoffsol's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCarp &raquo;</TD></TR><TR><TD CLASS="quote">
new MSD 6al box
MSD's eat ignitors like fat kids eat cake. I bet thats the problem. Same **** happened to Tbone's car.
I have a CEL of a VSS due to the fact that I put an LSD in and it keeps eating my VSS gears. Can this be aproblem? Could it not be jumping to high speed maps?
.[/QUOTE]
while i don't think this is a problem with breaking up (ignition maps are based off diztributor RPM, not VSS readings) its som,ethign to lok into as far as your LSD install
Old Oct 31, 2004 | 10:56 PM
  #35
On Fire!
I am useing an MSD blaster coil. I have just redid all my grounds and made sure that all wireing is correct.....I am still ahving the exact same problem...is there anyone near me that I can just take this thing to. Its killing me having this car here and not being able to use its potential.</TD></TR></TABLE>
Have you replaced the coil??
If you haven't its cheap and I would give it a try, i know of a fev coils that have caused 3 cars that I personally know of that have broken up up top.
Old Nov 1, 2004 | 01:12 AM
  #36
DOHCarp's Avatar
I have honestly replaced the coil with three diffrent working units, along with three diffrent ignitors, but still no luck.
Old Nov 1, 2004 | 01:20 AM
  #37
On Fire!
Have you checked all of the distributor wires to make sure the continuety (sorry bad spelling) is all the same from the ecu to the distributor?
Is your injector wiering streght, also is the resistor box for the injectors in good shape?
How about this does the car rev freely past 5000rpm when its just sitting there?
Modified by newgsr at 4:31 AM 11/1/2004
wantasol
Jul 28, 2009 03:32 AM
Black97DX
Apr 4, 2008 09:02 PM
kabaroo
10
Aug 28, 2007 04:13 PM
blkekcoupe
13
Aug 15, 2007 07:41 AM
Big James
Jul 13, 2001 01:55 AM
