OBX LSD - need shim!
Old Sep 15, 2006 | 05:39 PM
Enzo Speed's Avatar
Default OBX LSD - need shim!
So I'm doing a whole OBX write-up, but I can't get to the installation part because I need a shim aka B18 oil control ring.
Does anyone have some used B18 pistons lying around that is willing pull off a single oil side rail and ship it to me? It doesn't really matter if it's new/used, it's just being used as a shim.
Thread is here: https://honda-tech.com/zerothread?id=1752849
Help me finish!
Old Sep 15, 2006 | 06:26 PM
non-VTEC's Avatar
Default Re: OBX LSD - need shim! (Enzo Speed)
why not use the OEM shim in the tranny........you simply need to grind it down a little to make it fit.............it should take you no longer than 5min
Old Sep 15, 2006 | 06:32 PM
Enzo Speed's Avatar
Default Re: OBX LSD - need shim! (non-VTEC)
Grind it using what?
Old Sep 15, 2006 | 06:37 PM
non-VTEC's Avatar
small angle air die grinder with a sanding disk.
Old Sep 15, 2006 | 06:45 PM
Enzo Speed's Avatar
It's supposed to be 1.0 mm right?
Old Sep 15, 2006 | 06:58 PM
non-VTEC's Avatar
keep grinding the shim down until you get the proper clearence between the case half and the diff bearing. you can install the diff without all the other internals and just do a bunch of test fits before doing the final assembly.
1.0mm sounds about right i guess but its better to be sure.....every diff/case/shim will be diffrent.
Old Sep 15, 2006 | 07:21 PM
Enzo Speed's Avatar
Yeah, I was just trying to be lazy. Rechecking the clearance a bunch of times doesn't sound fun.
Old Sep 15, 2006 | 07:59 PM
nfn15037's Avatar
An oil control ring offers nowhere near the surface area that a differential shim provides. Is there something wrong with the OEM Honda shim selection?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Enzo Speed &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, I was just trying to be lazy. Rechecking the clearance a bunch of times doesn't sound fun.</TD></TR></TABLE>
Yeah, and a diff banging around inside the case, leading to a cracked case or worse sounds fun.
Old Sep 15, 2006 | 08:02 PM
igo4bmx's Avatar
Default Re: OBX LSD - need shim! (nfn15037)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nfn15037 &raquo;</TD></TR><TR><TD CLASS="quote">An oil control ring offers nowhere near the surface area that a differential shim provides. Is there something wrong with the OEM Honda shim selection?
Yeah, and a diff banging around inside the case, leading to a cracked case or worse sounds fun. </TD></TR></TABLE>
with the obx lsd, honda does not make a shim small enough to fit in between the housing and the diff
Old Sep 15, 2006 | 08:05 PM
Enzo Speed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nfn15037 &raquo;</TD></TR><TR><TD CLASS="quote"> Is there something wrong with the OEM Honda shim selection?</TD></TR></TABLE>
They don't go thin enough.
Old Sep 15, 2006 | 08:18 PM
nfn15037's Avatar
Default Re: OBX LSD - need shim! (igo4bmx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx &raquo;</TD></TR><TR><TD CLASS="quote">with the obx lsd, honda does not make a shim small enough to fit in between the housing and the diff</TD></TR></TABLE>
LOL quality
Old Sep 15, 2006 | 11:48 PM
turboedc2's Avatar
i used a honda shim on mines ....
Old Sep 29, 2006 | 03:37 PM
sohc_turd's Avatar
Default Re: OBX LSD - need shim! (Enzo Speed.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboedc2 &raquo;</TD></TR><TR><TD CLASS="quote">i used a honda shim on mines .... </TD></TR></TABLE>
Its been a while since i did mine but i beleive the oil control ring is .05.
and yes, i do have a couple of them left over. Feel free to pm me you address
Old Sep 29, 2006 | 03:46 PM
turbotime's Avatar
use the oil control ring as a shim with the obx lsd
thats how i shimmed mine and its still good after 2 builds
Old Sep 29, 2006 | 10:57 PM
sohc_turd's Avatar
Default Re: OBX LSD - need shim! (sohc_turd)
oops... yeah i meant to say that i used b18 oil control ring.
ive got a couple extra.
fjt
Apr 12, 2005 05:18 AM
mafay2
Sep 4, 2003 05:36 PM
-DC2-
Jun 2, 2003 06:08 AM
turbod92hatch
Feb 25, 2003 10:09 PM
satan_srv
Oct 8, 2002 12:57 PM
