OBX LSD install
Old Jun 22, 2006 | 03:19 PM
  #26
mike93boost's Avatar
need help. thanks
Old Jun 22, 2006 | 05:57 PM
  #27
ramennoodles's Avatar
Default Re: (mike93boost)
I did mine myself. it was my first time. not to hard to do. all I bought was two new bearings which was 10 bucks a piece at a local bearing shop. all other stuff was reused. shim was old one grinded down to fit. honda didn't have the right size i needed. lsd been working great for over a year now. there was a post on here that has detailed instructions on how to install lsd
Old Jun 23, 2006 | 01:31 PM
  #28
jfoster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93boost &raquo;</TD></TR><TR><TD CLASS="quote">need help. thanks</TD></TR></TABLE>
Seen this -&gt; https://honda-tech.com/zerothread?id=795700 ??
Old Jul 1, 2006 | 04:07 PM
  #29
Default Re: (jfoster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jfoster &raquo;</TD></TR><TR><TD CLASS="quote">Seen this -&gt; https://honda-tech.com/zerothread?id=795700 ??</TD></TR></TABLE>
the pics dont work.
Old Jul 2, 2006 | 09:19 PM
  #30
what are the NECESSARY parts i need to order form honda?
Old Jul 2, 2006 | 11:12 PM
  #31
I would say bearings and shim. old speed gear can be used, just heat it with a propane torch and it pulls right off. seals can be bought from local auto parts store if needed. the thing is that you won't know what size shim you need until you actually put the differential back in and bolt everything down. bearings can be reused but I didn't want to take the chance of not having a bearing if it was damaged during removal from old differential. my 2 cents
Old Jul 3, 2006 | 07:48 AM
  #32
everyone keeps talking about this damn shim, and i dont know what the hell it is.
Old Jul 3, 2006 | 09:12 AM
  #33
pgmatt's Avatar
Download the factory manual and you will see what everything is and how it works.It is pretty self explanatory.I just finished installing a OBX diff and Honda trannies are pretty easy to work on if its your first time.
Old Jul 3, 2006 | 01:03 PM
  #34
shim is the thin snap ring that goes between the differential bearing and the tranny case. on the tranny case there is a big snap ring. thats the shim. even though the pics don't work in the link above, it still has good info on how to do it. #4 in the link is where the shim info is
Old Jul 3, 2006 | 01:11 PM
  #35
Default Re: (ramennoodles)
take a look at this link: http://www.hondaautomotivepart...USING#7 is the shim
Old Jul 3, 2006 | 01:56 PM
  #36
thanks for the help.... which bearings should i get from hondaautomotiveparts?
Old Jul 3, 2006 | 02:06 PM
  #37
you need the #10 thats in the diagram. two of them
Old Jul 3, 2006 | 02:21 PM
  #38
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ramennoodles &raquo;</TD></TR><TR><TD CLASS="quote">you need the #10 thats in the diagram. two of them</TD></TR></TABLE>
cool thanks bro.. damn those are expensive haha.
im guessing you use a feeler guage to determine the shim you need?
and whats this i hear about people using a bseries oil control ring for the shim? what is that?
EDIT: btw the auto parts stores have the diff. bearings for way cheaper.. would those be fine or is this something i should stick with OEM?
Old Jul 3, 2006 | 03:34 PM
  #39
I'm using cheap 10 dollar bearings I got from a local bearing shop and they work great
Old Jul 3, 2006 | 06:57 PM
  #40
just bought some bearings from oreily. $19.99 each.
should start on the install tommorow. illt ake a bunch of pictures and hope i dont expletive anything up.
Old Jul 5, 2006 | 10:41 AM
  #41
pgmatt's Avatar
Just take your time and clean everything well.Good for you that your doing it yourself.
Old Jul 5, 2006 | 12:56 PM
  #42
DJ Gurgla GSR's Avatar
you got BALL BEARINGS or the tapered roller bearings? You want the ball bearings.
stock cylinder bore is 81mm. I believe the shim used for differential is also 81mm. So you COULD use an oil control ring for the shim (other people have done it) but if the clearance isn't right, you have to invest in a shim anyway.
Old Jul 11, 2006 | 02:33 AM
  #43
hondasniper's Avatar
Default Re: (DJ Gurgla GSR)
http://tech.hybridgarage.com/tech/fd-swap.html
http://tech.hybridgarage.com/tech/lsd/
hope this helps
Jeff_B
Dec 24, 2005 12:05 PM
litterbox
Apr 18, 2005 09:14 AM
nickromeo
Mar 7, 2005 06:07 PM
AL ASPIRATED
Feb 8, 2004 11:59 PM
Nameless RB26
Dec 9, 2002 08:53 AM
