cold air intake vs short ram for jrsc!!!!
Old 07-08-2006, 05:26 PM
pinoyk20's Avatar
Default cold air intake vs short ram for jrsc!!!!
hi i just got my jrsc kit running on my engine and im thinking which type of intake to use..... should i use a coldair intake that goes down up to the bumper or use a short ram ....... were will i get more power from the two....... im looking for topend power.
Old 07-08-2006, 06:00 PM
SavEM1's Avatar
The shorter the better for the JRSC.
Old 07-09-2006, 02:28 AM
Zer0_SpeedWorks's Avatar
hi martin!yep the short ram is better!try to pre fab a short ram pipe for ur filter...
Old 07-09-2006, 07:06 AM
sc4dr's Avatar
Default Re: (Zer0_SpeedWorks)
Shorter might be good for velocity to the blower, but the heat thats created kills it. I reccomend a cold air, just for cooling purposes. I made over 300whp with one on my blower setup.(not that it was because of the intake)
Old 07-09-2006, 08:52 AM
rmcdaniels's Avatar
Default Re: (sc4dr)
We tested it on the dyno at RLZ one day with my setup, a 3" AEM ITR CAI actually made the most power.
Old 07-09-2006, 09:33 AM
SavEM1's Avatar
Default Re: (rmcdaniels)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmcdaniels &raquo;</TD></TR><TR><TD CLASS="quote">We tested it on the dyno at RLZ one day with my setup, a 3" AEM ITR CAI actually made the most power.</TD></TR></TABLE>
did you also dyno filterless?
Old 07-09-2006, 09:48 AM
rmcdaniels's Avatar
Default Re: (Hcivic02)
Yes, most power was actually the 3" CAI filterless.
Old 07-09-2006, 06:57 PM
pinoyk20's Avatar
WAS IT topend 0r minrange power????? how about using a 2.5inch CAI?????
Old 07-09-2006, 07:02 PM
rmcdaniels's Avatar
Default Re: (pinoyk20)
We got about 8 WHP throughout the power band. I didn't try a 2.5" CAI, I have a 75mm throttle body.
Old 07-09-2006, 08:26 PM
pinoyk20's Avatar
how about for my set up ????? b18c1block b18c head type r. b16b cams,mugen headers, 64mm throtle body. what diameter should i use sir?????? so i guess i should go for CAI.....???????
Old 07-09-2006, 09:31 PM
SavEM1's Avatar
id spend the money on some a better JRSC friendly header...which isn't much really
Old 07-09-2006, 10:26 PM
pinoyk20's Avatar
i just got the header for free from my brother..... what should i go for CAI or shortram????? pls help me decide. thanks guys!!
Old 07-09-2006, 11:01 PM
LuderCriS's Avatar
get a short ram its better
Old 07-09-2006, 11:43 PM
SovXietday's Avatar
Default Re: (PreludeRGuY)
CAI will draw in cooler much cooler temps and will give you more power.
Old 07-10-2006, 10:25 AM
SavEM1's Avatar
Well if its always cool or cold in your area i'd pick up a SRI...if its not then the engine temps are going to climb and i'd get a CAI since the JRSC is a huge heat blower.
Old 07-10-2006, 11:03 PM
pinoyk20's Avatar
im from the philippines and its really hot in here so i guess ill just have to try it in the dyno...... what do you guys think?????? thanks!!!
Old 07-11-2006, 03:09 AM
sc4dr's Avatar
Listen to myself, rmcdaniels, and sovxietday. We have tryed numerous setups and CAI is what works the best...no matter what climate. I'd like to see proof from everyone on here that is chiming in and saying go short ram.
Old 07-11-2006, 03:11 AM
sc4dr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hcivic02 &raquo;</TD></TR><TR><TD CLASS="quote">id spend the money on some a better JRSC friendly header...which isn't much really</TD></TR></TABLE>
His Mugen header will work just fine
jdmsleeper12
05-14-2009 10:47 AM
HT Chaplain
02-27-2005 05:36 AM
escape2me
01-28-2005 07:06 PM
CKim
09-08-2004 03:48 PM
gubo22
02-01-2004 11:10 PM
Quick Reply: cold air intake vs short ram for jrsc!!!!
