OBD1 Convervion Injector ?
I have a b16 and i am going turbo and converting to obd1. What type of injectors am i supposed to use? the saturated or ...? TIA
Also 550 good enough size for a gt28r and 14psi? |
Re: OBD1 Convervion Injector ? (Ak_ef9)
obd1 and newer on a civic use saturated injectors, you can run up to a 750, they dont make above 750's in sturated that i am aware of. the injector size comes down to your h.p. goal.
Re: OBD1 Convervion Injector ? (boostedcivicsir)
even though i still have the resistor box i use saturated?
if you are using an obd1 ecu, use saturated injectors, untill you need to go larger then use p-h. but no you dont need a resistor box, right now.
You don't change injectors when covnerting OBD's. When buying injectors, get whatever style injectors you have right now.
