OBD TURBOING HELP PLZ!!!
Old Jan 10, 2011 | 06:31 AM
ch3ch3's Avatar
Default OBD TURBOING HELP PLZ!!!
I have a 98 ek coupe which obviously came with and obd2 ecu Which Im fine with the probelms comes when i look into turbong,tuning etc I would Like to keep my same OBD and Swap and Engine With the Same OBD which of course simplifies things. However I do want to turbo and have upgrades and what im reading thru research is that the obd2 is unchippable and harder to tune.Ive seen alot of ppl suggesting AEM EMS if I do decide to stay OBD2 Has anyone done this? and could someone plz give some light on this as i am a Noob and really started reading all this stuff today i dont understand why is OBD 2 so difficult to work with?????????
Old Jan 10, 2011 | 06:34 AM
macson's Avatar
Default Re: OBD TURBOING HELP PLZ!!!
Convert to OBD1.
Old Jan 10, 2011 | 06:36 AM
grumblemarc's Avatar
The Grumpiest
You should post this in the Forced Induction forum.
Get a p28 (OBD1) and a step-down harness.
Old Jan 10, 2011 | 07:12 AM
TheShodan's Avatar
Moderator
There are Harness adapters that can easily convert to OBD1 from Pherable.net and rywire. You would then keep your original OBD2 harness and run an OBD1 based ECU system. OR, you can Use Hondata that has the OBD2 plug in harness already integrated into the ECU. Most expensive possibility is to use AEM EMS
Old Jan 10, 2011 | 07:43 AM
ShopClosetSOHC's Avatar
OBD2 can be chipped/tuned but it's not going to be cheap. It would be cheaper and easier to convert to obd1 and find a tuner. Its really not hard to do
Old Jan 10, 2011 | 01:27 PM
ryguy2588's Avatar
Get an OB2 to OBD1 harness and a P72 or P28 ecu like everyone else is saying. I did it for my B16A swap and it works like a charm.
Old Jan 10, 2011 | 03:26 PM
hateshino's Avatar
+1
goto phearable.net and they have all the stuff you need. its exactly what i did and everything works like a charm
Old Jan 10, 2011 | 06:01 PM
HAMOTORSPORTS's Avatar
As everyone is suggesting, simply install an OBD2A to OBD1 jumper harness and a chipped OBD1 ECU. Tuning options are much easier this way and will perform much better than anything you will do with OBD2.
If you are concerned with installing a jumper harness and having extra wires, etc.. We offer the OBD2 Hondata P28 with S300 system installed. This is basically an OBD1 P28 ECU that has a built in OBD2 style connector which eliminates the need for a jumper harness:
http://www.hamotorsports.com/s300-obd2a-p28.html
Old Jan 11, 2011 | 03:35 AM
ch3ch3's Avatar
wow thnx for all the feedback i already like this more then civicclub lol and i started here yesterday. Im seriously considering going to obd1 Im good with anything but electrical system. lol so i was trying to avoid it but o well no run for lazy needto start learning an go OBD 1
Old Jan 11, 2011 | 04:36 AM
kyden's Avatar
going obd1 only requires an ecu and jumper harness. nothing else.
Old Jan 11, 2011 | 06:09 AM
The Grumpiest
There is nothing involved past getting an OBD1 ECU and plugging up the harness. So it is literally plug and play. There is no messing about with the electrical system.
Old Jan 11, 2011 | 06:42 AM
hateshino's Avatar
so easy a caveman can do it! lol
Civic98KH
Mar 11, 2007 09:21 PM
97DGreenEx
Oct 13, 2006 06:21 PM
NsX_CrX
Nov 19, 2005 12:49 PM
shawnc21
Jan 9, 2003 11:21 AM
