NX wet kit?
Old Jun 21, 2005 | 06:27 PM
darkblue1998ls's Avatar
Default NX wet kit?
I have a 98 integra ls and want to run a 100 shot.Can the stock internals handle it?I have been running a 75 shot with just a larger fuel pump and have had no problems now I have added an MSD ignition box and coil would this also be sufficient enough.Thanks for all info!
Old Jun 22, 2005 | 06:06 AM
B16Civic93's Avatar
Default Re: NX wet kit? (darkblue1998ls)
well i would do a compression test on the motor to see exactly what state it is in. then if all goes well with that i would definately get colder spark plugs if you havnt done so. and i dont know if your msd box retards timing when under the bottle but if not i would retard it a few degrees.
and lastly if you are worried about reliability i would only run a 100 shot through direct port, i'm sure people will argue that it is ok through a wet shot only but that is my opinion, i think a direct port is much safer than a wet fogger shot.
g/l
shhh151
May 26, 2006 08:20 PM
hondaeg8
Oct 7, 2004 10:57 PM
Slopoke
Apr 29, 2004 03:25 PM
Sohc Driver
Dec 14, 2002 02:58 PM
dvp95
Jun 5, 2002 11:24 PM
