Ignition systems and nitrous
Old Apr 29, 2004 | 02:37 PM
Slopoke's Avatar
Default Ignition systems and nitrous
I know guys are running 400whp with turbos on stock ignitions.
Can the same hp be reached with nitrous on a stock ignition system?
If not, what is the limit?
I'm looking to put an 80 shot on a motor that is currently putting 200hp to the wheels, NA.
Should I invest in an aftermarket ignition system or not?
I've been hearing both "yes" and "no"
Anyone with any actual experience?
Old Apr 29, 2004 | 02:49 PM
whatVTEC's Avatar
Default Re: Ignition systems and nitrous (Slopoke)
I'd at least run a MSD Digital6 because it has the nitrous retard. or use somthing similar
Old Apr 29, 2004 | 03:01 PM
Slopoke's Avatar
Default Re: Ignition systems and nitrous (whatVTEC)
I plan to manually retard the timing at the track, so is it still necessary?
It will very rarely be used on the street.
Old Apr 29, 2004 | 03:25 PM
Kataku2K3's Avatar
I personally will only run a nitrous motor with an aftermarket ignition where as with some low boost turbo motors you can get away with a factory setup. Reason being is generally we run them a bit richer and it does take more power to fire. I'm sure you could get away with it but I would just toss something on there. If you don't want to spend a lot of money go with a 6A or 6AL. The Digi6 is a nice box as it's got a built in 2-step and retard features as whatVTEC said. If you want something with more output the MSD 6 HVC boxes are also another option. In the end I guess it's up to you. Good Luck
MARVNVRAM
Oct 2, 2007 03:53 AM
imptricer
Aug 5, 2007 11:00 AM
baphomet
Oct 14, 2003 06:58 AM
p1ccoloz
Mar 9, 2003 04:18 PM
dvp95
Jun 5, 2002 11:24 PM
