Now boosted and can only go to 5500 rpm@!$%$#@ Please help!!!!
I drive a 94 integra with a b20b, i got my turbo kit installed last wendsday and i still have a problem. the car runs fine and it pulls hard but when i get to 5500 rpm it seems like the engine cuts out and then it kinda starts again. the guy that installed it took it for tuning and they couldnt figure it out. he says that it is because the engine is getting too much fuel and that the engine kinda plogs out. is that what's going on? if so, how can we fix it? or is it something else? i'm running a vafc with 450's. Please help!! I will post up a picture of the dyno sheet later.
how much boost, what size/kind of turbo?? more info please??
do they even have the setting for more than 1 bar of boost???
are you getting any check engine lights??
Re: (mrbsponge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge »</TD></TR><TR><TD CLASS="quote">how much boost, what size/kind of turbo?? more info please??
are you getting any check engine lights??</TD></TR></TABLE>
Garrett t3/t4
coldside: 60 trim, 60 ar
hotside: stage 3 turbine, .48ar
.4 bar
no check engine lights
i will ask about the 1 bar of boost thing, i'm new to the game and dont know all them terms yet. Let me know what you think it might be. thanks!
Modified by redb20teg at 6:07 PM 6/10/2005
Modified by redb20teg at 6:25 PM 6/10/2005
Garrett t3/t4
.4 bar
Re: (SoSlo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoSlo »</TD></TR><TR><TD CLASS="quote">sounds like an ecu problem
what about the ecu, what would i need to do?
Re: (redb20teg)
when my ecu would not let me rev above 3300rpm it turned out to be a bad input into the ecu.
check your vafc conections are they soldiered?? have you tried to reset your ecu ?
Re: (SoSlo)
sometimes the VAFC hack setupi makes it bog . 5500 is right where your vtec kicks in. this happen to me before. unfortunateley its kind of a hit or miss. never foudn a fix for it .
you shoudlnt run the AFC hack setup anyways.
Re: (project dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 »</TD></TR><TR><TD CLASS="quote">sometimes the VAFC hack setupi makes it bog . 5500 is right where your vtec kicks in. this happen to me before. unfortunateley its kind of a hit or miss. never foudn a fix for it .
you shoudlnt run the AFC hack setup anyways. </TD></TR></TABLE>
cool man, that's crazy, i hadn't realized that. so you think i should use something else other than the vafc? what else could i use? is that the only way you got rid of that problem?
Re: (redb20teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redb20teg »</TD></TR><TR><TD CLASS="quote">
cool man, that's crazy, i hadn't realized that. so you think i should use something else other than the vafc? what else could i use? is that the only way you got rid of that problem?</TD></TR></TABLE>
read it i said i havent found a fix. no one really rusn the aFC hack anwyays. esp with better programs out and htey're free etcc
