Not Holding Boost
Old Apr 9, 2006 | 06:18 PM
The Jacko's Avatar
Default Not Holding Boost
Yesterday I got my vehicle tuned and for some reason it was not holding boost. We went to tune for 28psi but it wouldn't hold. I was thinking that I never adjusted the valves for this setup and that the valves are staying open which is probably causing the boost to fall off. What do you guys thinks? Also, the tuner told me I should get a set of type R cams.
Old Apr 9, 2006 | 06:20 PM
slowteg550's Avatar
Default Re: Not Holding Boost (The Jacko)
wow, it could be a number of things. I mean, is it holding a certain psi, like 13 or 15, etc,...or is it getting to 28 and then falling off? what exactly is it doing?
Old Apr 9, 2006 | 07:11 PM
The Jacko's Avatar
Default Re: Not Holding Boost (slowteg550)
it holds 24psi but nothing high
Old Apr 9, 2006 | 07:20 PM
slowteg550's Avatar
what is your wastegate spring, 12 psi?
Old Apr 9, 2006 | 07:50 PM
97turboteg's Avatar
have you checked your Blow Off Valve? do a boost leak test
Old Apr 10, 2006 | 04:00 AM
The Jacko's Avatar
I believe it is 7 or 8psi spring
Old Apr 10, 2006 | 04:01 AM
The Jacko's Avatar
Default Re: Not Holding Boost (97turboteg)
how do i do that
Old Apr 10, 2006 | 05:27 AM
JDM00SI's Avatar
If you have a 7 psi or 8 psi spring, you can't double that psi. So you'd be capable of boosting 14 or 16 psi....
Old Apr 10, 2006 | 10:36 AM
The Jacko's Avatar
Default Re: Not Holding Boost (JDM00SI)
I have an innovate boost controller and they say that you boost as high as the controller can hold,but nothing under what ever the spring is
ralph11sec
Feb 25, 2009 10:27 AM
1990hondaHF
Jan 16, 2008 11:57 AM
vg7z
Sep 20, 2006 08:27 PM
SPOOLINmatt
Apr 16, 2005 10:13 PM
92jdmhatch
May 4, 2004 12:10 AM
