NOS???
Old Feb 23, 2004 | 10:17 AM
cw98typer's Avatar
Default NOS???
Kind of a newb ? but I'm not too experineced when it comes to nos...ANyway, whats the highest compression u could run on a b18c5 with a 100 shot, and whats the biggest cams u could run on the same setup. This is a daily driver setup
b18c5
sleeved block
12.0 84mm piistons
fully built head w/ stage 2 or 3 pnp job
all the other bolt ons and tuning will be added
Would this be safe or no?
thanx
Old Feb 23, 2004 | 11:39 AM
Infinite Auto's Avatar
Default Re: NOS??? (cw98typer)
well im not the biggest nos guy in the world.....but i ran a 75 shot on a 88 crx si for months (spraying a few times daily) with no problems.......and that was a stock motor with 155k miles.....so you just wanna run 25 more and you say you have a fully built motor.....im sure your fine to run 150......just make sure the tuning is good......need lots of fuel with nos
Old Feb 25, 2004 | 03:23 PM
RockstarJR's Avatar
Brent....
NO nos on the R. Especially with the raised CR
Call me
Chris
Old Feb 25, 2004 | 05:40 PM
J337_UNIT's Avatar
Default Re: NOS??? (RockstarJR)
nitrous and high compression = a no no...your motor could probably handle it however its just very risky and no worth it IMO.
Old Feb 29, 2004 | 08:36 AM
camaronut502's Avatar
Im planning on running crvtec with a 100-150 shot, and im new to NOS so i was also wondering whats a safe compression ratio.. Any info would be great,
thanks, Matt
Old Feb 29, 2004 | 10:25 AM
turbogeekDA6's Avatar
Default Re: NOS???
im building a b20 with ported head and some rm cams... compression on my setup is around 10.3 and im using a 100 shot. i think mid-low 10s is a great cr for a street "nitrous" motor. the car will still be responsive off juice. if you are going to spray this much i highly suggest that you jet the 100 shot slightly richer than the already rich factory jetting. (to counteract fuel getting trapped in an intake that was only designed to flow air). i have done a lot of research and the guys that make 100 shot work reliably on stock motor are all doing this. also, run the best gas you can get. its just not worth it to toast an expensive motor running cheap fuel. forged pistons are the way to go but you can make the stock ones work if you can write knock out of the equation. the first key to making your motor last, ie not detonating on n2o, is having enough octane for your combination. the second key is to make sure the car NEVER goes lean. install a fuel pressure safety switch. also, pull 3-4* timing only under nitrous activation with sn msd switch. ignition and fuel systems need to be functioning at their best as well. upgraded pumps/afprs are very welcome on you setup. btw...what nitrous kit are you using?
Old Feb 29, 2004 | 11:01 AM
alloutmotor's Avatar
i dont think high compression nitrous is bad...if you are running a well planned out direct port setup you shouldnt have a problem
Old Feb 29, 2004 | 11:02 AM
Default Re: NOS??? (turbogeekDA6)
Thanks for the info
dirtrdr22CRX
Aug 27, 2009 10:41 AM
le0ftw
Mar 24, 2007 10:44 PM
Mackenzie
Oct 25, 2004 08:24 AM
NirVTEC
Feb 17, 2004 10:38 AM
mr2
Oct 24, 2001 01:38 PM
