NOS!!!!!!!!!!!!!!!!!!!!!!!
I have a 2000 civic si. I'm in the middle of installing a universal dry nitrous oxide system from NOS/Holley. I need to know what's the best way to install the fuel pressure safty swith that came with the kit. It says that I need to drill and tap into the banjo bolt on the fuel filter. Is their any other way or is that just what I'm going to have to do? If so, can anyone tell me the best way to go about doing it?
[Modified by jthomas, 3:34 PM 2/4/2002]
You could probably just cut the fuel line and install a tee fitting that you can thread the pressure switch into, but most people don't like running hose barbs and clamp fittings at high fuel pressure.
Checkit...go get a B&M fuel pressure gauge...then run a t off of that...should look similar to this:
I have my FPSS, gauge, and fp sensor for internal gauge mounted there...now I have a wet kit so I moved it to right in front of the fuel solenoid.
-ryan
-ryan
92SiB18C1
Apr 25, 2003 05:35 AM
