normal oil burning
There a lot of mistake about oil burning in f/i...what should be the average oil consumption for a 30000 km 18 psi turbo setup??my engine take 50ml at each 2000km yes a healty engine should never burn oil.. my compression is good and leakdown to
18psi equals what again?
i believe some oil will burn due to the temp of the turbo will create. how much oil will burn is beyond me, just check it every weekend
b18b forged,,420whp..setup as 30 000 kilo and i do my oïl change every 2000k...the setup burn 30-50 ml of oïl between oïl change..i use formula gulf 5w-40..im not so scared,,,most type-r and vtec setup here(N/A) take a LOT of oil,,,just wanted to know common oïl burning on a healty Honda turbo setup,
depends upon the clearances of the bearings as well as how often you're going at full load. It is common for about a quart or so between changes.
I work for Honda, and they state that 1 qt every thousand miles is acceptable.
I think it's a bullshit thing they say just so they don't have to warranty the new accords and v6's that burn oil and foul out plugs like no ones business. But, there it is...
mrsteezy123
May 4, 2017 03:29 PM
superhatchbackbros
Aug 16, 2006 01:02 PM
