noob question
Old Nov 2, 2006 | 07:05 PM
drift_n_shift's Avatar
From: Off the Florida Keys, in a place called Kokomo, USA
Default noob question / mini me advice
i have a few questions about the dseries block
i have a 1992 civic si...
i want to do a turbo d setup but not on the current motor. i want to build a new one. my question is, what is better
-i can get a bare, bare, stripped d16z6 for $30 (83k on it, pro cleaned) and i was thinking on building it. i can also get a pretty much full bottom end d16a6 (rebuilt 60k ago) for $50. i have a vtec head already so i was wondering what is a better building up. im going to do a vitara or forged piston setup, so im going to replace the pistons regardless. even with a turbo, i want something reliable too. or should i buy a complete d16z6 botttom(with like 200k+)
-is the mini me reliable/ worth doing? whats the better setup?
thanks inadvance
Modified by drift_n_shift at 8:54 PM 11/2/2006
Old Nov 2, 2006 | 07:08 PM
Jcup315's Avatar
Default Re: noob question (drift_n_shift)
if the full bottom end build is sleeved then go with that...then you don't have to worry about it later.
Old Nov 3, 2006 | 07:05 PM
Default Re: noob question (Jcup315)
its not sleeved...
anyone else?
Old Nov 4, 2006 | 04:47 AM
b18sihatch's Avatar
well the thing is ''Mini Me'' is basicly a high compression motor
d16a6 block
d16z6 sohc vtec head
once boost high compression isnt going to be needed so just go with a d16z6 block
but also, understand what its going to take to build a block that is going to be able to withstand turbo/psi
PrettyFastRide
Nov 2, 2015 03:14 PM
Arseezy
Engine Management and Tuning
Aug 25, 2011 08:10 AM
fryguy190
18
Jul 5, 2011 04:10 PM
buskethead
May 20, 2003 04:02 PM
