noob question
Old Jul 16, 2005 | 11:34 PM
b18cEF9's Avatar
Default noob question
vacume for the BOV is hooked upto the back of the intake mani, is the BOV supposed to be open at idle?
Old Jul 16, 2005 | 11:37 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: noob question (b18cEF9)
on most bov's, yes it will be open at idle
Old Jul 16, 2005 | 11:51 PM
b18cEF9's Avatar
its a dsm bov
Old Jul 16, 2005 | 11:56 PM
adseguy's Avatar
as long as it shuts closed when you give it some throttle everything is ok
Old Jul 17, 2005 | 07:30 AM
Boosted Power's Avatar
Default Re: noob question (adseguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">as long as it shuts closed when you give it some throttle everything is ok</TD></TR></TABLE>
Old Jul 19, 2005 | 09:27 PM
b18cEF9's Avatar
Default Re: noob question (Boosted Power)
is it suposed to have a rubber O ring on the valve that opens and closes, so it gets air tight? cuz mine doesnt and i have some boost leaks and i cant figure out where, already checked fmic, pipes... yada yada
Old Jul 20, 2005 | 02:35 PM
b18cEF9's Avatar
anyone?
Old Jul 20, 2005 | 02:40 PM
Benjithx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cEF9 &raquo;</TD></TR><TR><TD CLASS="quote">is it suposed to have a rubber O ring on the valve that opens and closes, so it gets air tight? cuz mine doesnt and i have some boost leaks and i cant figure out where, already checked fmic, pipes... yada yada</TD></TR></TABLE>
not necassarily, a machined surface under pressure should hold
autowrench07
Aug 23, 2008 06:13 PM
K.Doe[shift]
Oct 26, 2007 11:30 AM
welfarepc
Aug 19, 2007 08:26 PM
Steve91
Nov 23, 2005 09:22 AM
the.hamburglar
Jun 2, 2005 02:29 AM
