noob question......
Old Jun 2, 2005 | 12:58 PM
TSteknicks's Avatar
Default noob question......
can i connect my bov and boost gauge from fpr tube? is there better place to use vaccum source?
Old Jun 2, 2005 | 01:05 PM
adseguy's Avatar
Default Re: noob question...... (TSteknicks)
IMHO doing one or the other is ok, but if you do both then you have 3 devices using one small vaccum source and this can slow the "signal" down or worse case not provide enough (no experience or heard anything, just my opinion).
I bought a GE vaccum manifold to split up the devices off the BIG brake booster vaccum source, but otherwise you can drill you manifold, or better yet Tee somewhere else. GL
Old Jun 2, 2005 | 03:39 PM
B16Civic93's Avatar
Default Re: noob question...... (adseguy)
i have ALL my vac sources coming off of the fpr vac line,and no problems so far
Old Jun 3, 2005 | 02:40 AM
TSteknicks's Avatar
i have another question.... when i'm in neutral do i have to see pressure? because i only see vaccum when i'm in neutral
Old Jun 3, 2005 | 04:36 AM
EK_GSR's Avatar
Default Re: (TSteknicks)
yea only vaccum when ure in neutral.
Old Jun 3, 2005 | 05:45 AM
blaze the chemi's Avatar
I have my BOV connected to a Tee at the top of the manifold and my gauge is Teed from behind the manifold. My FPR is Teed with my boost controller. I only try and hook 2 things to a single vacuum source. Yes you should see a vacuum in neutral. Should be around 18-20 inHg. w/o AC, lights and otehr stuff.
Elevorett
19
Dec 24, 2009 07:31 AM
oodie
Sep 11, 2009 08:51 PM
superslow-oto
Oct 30, 2007 11:43 AM
95hatchfire
Aug 17, 2004 12:17 AM
