Help please Vaccum manifold hookups
Old Sep 9, 2009 | 09:47 PM
oodie's Avatar
Default Help please Vaccum manifold hookups
I have quick question i have fast-turbo vaccum manifold and victor x intake manifold. I know i T off brake booster after check vavle to the vaccum manifold other line goes to manifold.I know i run bov and boost gauge to vm.
I think wastegate port to manual boost controller then boost controller to vaccum manifold right? Or do i do each one to its own port in vm? Also does fpr still go to back port on intake manifold? Or do i have it all off
Old Sep 9, 2009 | 10:11 PM
jetspeedz's Avatar
Default Re: Help please Vaccum manifold hookups
you can t everything off if you want ideally you want the wg source from the turbo compressor or charge pipe anything before the tb but that is up for debate, yes the fpr connect to the manifold doesnt matter where as long as its after the tb
Old Sep 9, 2009 | 11:32 PM
oodie's Avatar
Ok so i go turbo mbc to wastegate and thats it for that? Bov and boost gauge i can t off the fpr or either run to the vaccum manifold if i hook it up?
Old Sep 10, 2009 | 08:53 AM
jetspeedz's Avatar
here is a basic hookup with manual controller
http://www.tmaturbo.com/install/boos...lerdiagram.jpg
Old Sep 10, 2009 | 09:20 AM
1DayIllBFast's Avatar
If you have a vaccum manifold use it. dont t anything off if you dont have to man. it is best if everything has its own source.
Old Sep 10, 2009 | 09:39 AM
oodie's Avatar
Ok im figuring it it out but last question. A few diagrams are different do i go turbo to boost controller then to wastegate? The diagram posted says wastegate to boostcontroller to a vaccum source.
Old Sep 10, 2009 | 09:41 AM
for the MBC...it has nothing to do with hooking to the turbo. it goes from bottom port of wastegate to the MBC then MBC to source on manifold.
Old Sep 10, 2009 | 10:26 AM
Schister66's Avatar
Man U FTW
Here is how i ran mine. I have changed it slightly since, but nothing major
Old Sep 10, 2009 | 10:53 AM
oodie's Avatar
Thanks that helped alot
Old Sep 11, 2009 | 08:28 PM
oodie's Avatar
Aight fellas thanks for the help but one more question. If i go from wastegate to boost controller to vaccum. Do i use this port or what do i do with it. Turbo is SC61 my last turbo didnt have this fitting?
Old Sep 11, 2009 | 08:31 PM
jetspeedz's Avatar
you hook up that nipple inline with the controller to your WG
Old Sep 11, 2009 | 08:46 PM
oodie's Avatar
Thats what i thought but if i run that to wasgate how to i run wastegate to vaccum source or do i T it off?
Old Sep 11, 2009 | 08:47 PM
srmofo's Avatar
those victor x manifolds have several vacuum ports on the rear of them. Why are you still using a vacuum manifold?
Old Sep 11, 2009 | 08:49 PM
jetspeedz's Avatar
look again at this diagram
you use this port instead of running it after the tb which is what it shows in the pic, the manual controller runs inline with it. you have a manual controller right
oodie's Avatar
Bought it used and i dont know the fitting size to use for it. i see them on back of manifold though.
Old Sep 11, 2009 | 08:51 PM
jetspeedz's Avatar
technically wg is never to see vacuum but like i said in my first post its up for debate, tial dos not recommend it while others say not to worry. or run it off the manifold and use a check valve simple
Vagitarian
Oct 17, 2014 01:22 PM
TSteknicks
Jun 3, 2005 05:45 AM
adseguy
Sep 21, 2004 09:34 AM
X-Mazda 3 Racer
May 21, 2003 08:40 PM
