noob greddy turbo kit question
I bought a used greddy turbo kit, and I was just wondering what people use to get the manifold to bolt to the block.
I know it sounds stupid, but the bolts that are usualyl used to hold in a header are too long to fit into the holes of the turbo manifold included in the greddy turbo kit.
The only solution I could think of was to get some extra studs, liek the ones you find on the left and the right side of the block that connect to the manifold to the block, The ones you only use a nut to secure it down.
And Im sorry for the wording of this.. My mind is working slow tonight and I couldn't think of a way to word it for the life of me.
thanks in advance.
thanks in advance.
Re: (PnoyEj6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PnoyEj6 »</TD></TR><TR><TD CLASS="quote">Bro you dont make sense. Just reuse your header bolts. I reused my header bolts from old gsr and the greddy manifold bolted perfectly</TD></TR></TABLE>
I tried to stick the bolt through the flange on the turbo manifold to bolt to the block, but the angle to slide the bolt through is too great.
Re: (nWilk666)
which motor? on my b16 the greddy came with a few studs that threaded into the block and just put a nut over it. use a little blue loc-tite to hold it tight and its great.
http://<a href="http://greddy.com/im...df/776.pdf</a>
** instruction manual. contains part's list
Obie
10-31-2003 12:57 PM
