non FMIC
Old Oct 6, 2005 | 06:07 PM
nitekidsef9's Avatar
Default non FMIC
anyone here running 6-8psi on a stock b16 and no FMIC?
cheers
Old Oct 6, 2005 | 06:26 PM
low430's Avatar
Default Re: non FMIC (nitekidsef9)
not a good idea, hot air in the motor = low power and harsh on the motor
Old Oct 6, 2005 | 06:30 PM
Origin's Avatar
Default Re: non FMIC (low430)
yeah. just not worth it. spend some money on one of these https://honda-tech.com/zerothread?id=1394180 that way you at least have a nice starting point. not sure on the specifics of these ic's but you can read for yourself.
Old Oct 6, 2005 | 07:00 PM
Default Re: non FMIC (Origin)
I also remebered that the Vortech S/C 6psi kit doesnt have a IC . So at 6psi should i be fine?
Old Oct 6, 2005 | 08:00 PM
wantboost's Avatar
Who is Mr Robot?
just because it doesnt come with one doesnt mean its ok.... at 6psi you should be ok... but its not the best thing to do.
Old Oct 6, 2005 | 08:02 PM
Adam.C's Avatar
why not run one? Pick up a JRC intercooler, or classifieds have some for cheap......
Old Oct 7, 2005 | 03:28 AM
Default Re: non FMIC (orangerex04)
my problem is the FMIC i have is 21x9x3 and i drive a JDM front end ef9. I looked behind the bumper and there is literaly NO room for one or my 2.25" pipes. So i wanted to get a custom one made the same size as a eg rad and run it beside my rad next summer.
Old Oct 7, 2005 | 05:17 AM
Adam.C's Avatar
is your bumper supprot on there? You can just saw stuff off and make it fit. Not many times will you not have to with a EF.
Old Oct 7, 2005 | 01:32 PM
no rebar ....... im going to make a custom one out of the old core
Old Oct 8, 2005 | 04:06 AM
JSPECSIR's Avatar
the ford probe intercoolers fits beside the radiator. guy I work with has one on his civic. hes ran about 13 pounds through it with no problems. hes on h-t his name is freshpizzaguy. hope this helps
Old Oct 8, 2005 | 05:38 AM
Default Re: non FMIC (5THGENSI)
thanks a lot
now i know what to look for cheers bro
tippmann_a-5_tyler
Oct 7, 2009 03:52 AM
turbo-crx
Jun 6, 2008 02:01 PM
ATS*Mark
May 15, 2004 04:37 PM
Freemantle
Apr 6, 2004 07:45 PM
98civicEX
Apr 16, 2003 06:52 PM
