help with oil catch can quesiton
Old Oct 8, 2005 | 03:40 AM
zbaber's Avatar
Default help with oil catch can quesiton
ok.. my car will hopefully be finished today (88crx with ls turbo setup).. i was wondering.. do i need an oil catch can setup? currenly i have no line running from my charge pipe to my valve cover.. i was just gonna stick a breather on the valve cover... but a friend said i needed the vacume line from imy charge pipe to valve cover... i was thinking about it... wouldnt that pressurize the crankcase under boost? there isnt a 1 way valve in there.. so how would that help? let me know if im seeing this wrong.. and the right way to set it up. thanks in advance
Old Oct 8, 2005 | 06:45 AM
bubs's Avatar
You're right and your friend is wrong. As soon as boost starts to build, it will create positive pressure in the crankcase which is obviously bad. Look up one of the many catch can threads, they'll tell you what you need to do.
aleks77
Nov 10, 2022 01:51 PM
kreatekustomz
May 21, 2010 09:11 PM
keenspeed94
May 2, 2007 01:00 PM
THEDirtyDseriesWOOT
Aug 31, 2006 01:23 PM
nerdsports
May 10, 2003 11:47 AM
