No Voltage at Injectors?
Old Jul 6, 2021 | 05:10 PM
justajeepguy's Avatar
Default No Voltage at Injectors?
Hey guys, I've been trying to boost my 91 teggy with a b16. Been trying to start it and just found out I have no voltage at my injectors all of a sudden. There is also no voltage out of the resistor box, I was wondering how could I test the power into the resistor box or could it be something else? Ecu was working fine when I took it out to obd1 swap. Car did not run after swapping everything over to obd1 so I wanted to see if it would run with the stock injectors, ecu and dizzy.
Any input would be helpful.
Thanks
Old Jul 6, 2021 | 08:23 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: No Voltage at Injectors?
On the engine harness side of the resistor box plug, there are 4 red/black and 1 yellow/black wires. The yellow/black wire is the 12v power IN and the 4 red/black wires are the 12v power out to each of your fuel injectors. If the resistor box is damaged, there will be no power out on one or more of the 4 red/black wires. If you have no 12v power on the yellow/black wire, you need to find your issue there. Did you modify the original '91 Integra engine harness or plug in a different year/model engine harness ?
Old Jul 7, 2021 | 05:58 AM
7rrivera7's Avatar
I would test the ECU in another car.
Old Jul 9, 2021 | 06:41 PM
Old Jul 13, 2021 | 12:24 PM
So I checked my connections one more time and turns out the one was loose, I now have power to the injectors but still no start. I have fuel to the rail, power to the injectors and spark... but still no start. stock injectors are in, stock ecu, havent touched the harness since the swap, and same dizzy. Would the hondata im intalling in the new obd1 ecu fix this?
Thanks for the input.
Old Jul 13, 2021 | 11:33 PM
Txdragon's Avatar
Is the resistor box stock and meant for your stock injectors? If not, What injectors were you initially trying to use here?
Old Jul 14, 2021 | 01:58 PM
JRCivic1's Avatar
10 Year Member
Community Builder
OP, when you say "swapped everything over to OBD-1", what parts did you change ?
accordin 2 me
Dec 16, 2011 06:00 AM
e jay one
Aug 6, 2005 02:48 PM
Skinflute22
Apr 17, 2005 07:00 AM
fourthgenhatchB17
Apr 26, 2004 10:01 AM
truent
May 5, 2003 12:15 AM
