no start with msd BTM........
Old Feb 22, 2004 | 06:31 PM
99lspwr's Avatar
Default no start with msd BTM........
As the topic states...The car will crank, but will not start....This is the universal btm by the way, not the 6btm.....I hooked up the red wire to a switched 12v source, black to ground, white to coil negative, and yellow to wht/blue wire...I also tried to switch the white and yellow wires around with no luck....I bought this used, so I am not sure if it is good or not....Anyone got ideas, or does this sound like a bad unit????
Old Feb 22, 2004 | 06:36 PM
Mase's Avatar
Default Re: no start with msd BTM........ (99lspwr)
check to see if you're getting spark to ur plugs...
also check for blown fuses
Old Feb 22, 2004 | 06:43 PM
99lspwr's Avatar
Default Re: no start with msd BTM........ (Mase)
I did not check for spark at the plug, but when I disconnected the btm, and hooked up the stock wires, it fired right up....Does the wiring sound correct???
Old Feb 22, 2004 | 07:01 PM
Nid Styles's Avatar
Put it back in, and see if you didn't connect the wires the first time.
Old Feb 23, 2004 | 04:31 AM
99lspwr's Avatar
Default Re: no start with msd BTM........ (nd_styles)
I double checked the wires, everything was hooked up.....Still no spark...Is there any way to test the msd unit to see if it is working properly???
GraphiteMW
Nov 7, 2006 03:55 PM
TehMan
Feb 17, 2006 11:18 AM
CivicSiRracer69
Nov 27, 2004 12:30 PM
Yambor
Jul 30, 2004 06:55 AM
Sir_Phobos
Feb 17, 2003 09:12 AM
