No love.....
Old Jul 31, 2003 | 08:10 PM
  #51
tony1's Avatar
Default Re: No love..... (boosted92)
I've got a weldon scavenge pump in stock if you need one, that should definitely solve the problem.
Old Jul 31, 2003 | 08:13 PM
  #52
GraphiteAccord's Avatar
Default Re: No love..... (Dr.OnPoint)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr.OnPoint &raquo;</TD></TR><TR><TD CLASS="quote">reweld the fitting on the oil pan lower</TD></TR></TABLE>
won't the fitting then be too low and the oil will still back up?
Old Aug 1, 2003 | 04:22 AM
  #53
Blown90hatcH's Avatar
Default Re: No love..... (spoolinlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolinlude &raquo;</TD></TR><TR><TD CLASS="quote">
What size is the feed line(top)? The return line looks fine, you are a little vague as to where its coming from, is it definatly the bottom of the turbo? It could possibly be that the top line is too big/small...... give me some more specs on the lines, and where exactly the oil is bruning from</TD></TR></TABLE>
The specs on the feed is above. -3 and -8 return. I solved the prob.
Old Aug 1, 2003 | 04:23 AM
  #54
Default Re: No love..... (GraphiteAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GraphiteAccord &raquo;</TD></TR><TR><TD CLASS="quote">
won't the fitting then be too low and the oil will still back up?</TD></TR></TABLE>
Yep
Old Aug 1, 2003 | 07:00 AM
  #55
youngkow's Avatar
Default Re: No love..... (Blown90hatcH)
How did you fix the problem?
Old Aug 1, 2003 | 07:30 AM
  #56
ehhguy's Avatar
Default Re: No love..... (youngkow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by youngkow &raquo;</TD></TR><TR><TD CLASS="quote">How did you fix the problem?</TD></TR></TABLE>
he says the answer like 5 posts up. why can't people read an entire thread before posting????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH &raquo;</TD></TR><TR><TD CLASS="quote">I contacted moroso before I started this thing and they said it will hold 5 quarts and be under the oil return fittings. Stupid fools. The pan will only hold 4.1 quarts before it reaches the oil return fitting. Hopefully that solves the problem.
Thanks alot for all your help!!
Old Aug 1, 2003 | 07:49 AM
  #57
badCRX's Avatar
New User
Default Re: No love..... (ehhguy)
Uhh, he said "hopefully" that solves the problem. He never said "problem solved".
Some people take things literally, and to me the previous statement doesn't verify the problem has stopped as well.
Old Aug 1, 2003 | 10:27 AM
  #58
boosted92's Avatar
Default Re: No love..... (badCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by badCRX &raquo;</TD></TR><TR><TD CLASS="quote">Uhh, he said "hopefully" that solves the problem. He never said "problem solved".
Some people take things literally, and to me the previous statement doesn't verify the problem has stopped as well.</TD></TR></TABLE>
Some people don't read. Look up maybe 4 posts.
The specs on the feed is above. -3 and -8 return. I solved the prob.</TD></TR></TABLE>
Old Aug 1, 2003 | 11:56 AM
  #59
h22 civic's Avatar
could ya tell me a little more about the scavage pump im interested in one what do i need and it is supposed to be street able just give me the run down it foe a h22 turbo
Old Aug 1, 2003 | 01:55 PM
  #60
youngkow's Avatar
Quote, originally posted by Blown90hatcH »
I saw this, and I saw what he posted what moroso said but I just wanted to make sure. I had the same problem, and I wanted to make sure I didn't get the same problem in the future.
Old Aug 1, 2003 | 02:38 PM
  #61
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by youngkow &raquo;</TD></TR><TR><TD CLASS="quote">Quote, originally posted by Blown90hatcH »
For some reason I trusted moroso. They said yes....5 quarts is under the oil return fitting. I was only able to get 4.1 quarts before it reached the oil return fitting.
Old Aug 1, 2003 | 08:18 PM
  #62
saso
Guest
Posts: n/a
Moroso parts for imports are boo. I stated this a while back and got flamed for it.
I had to dump my Moroso oil pan, I bought a Moroso control arm and while I was drag racing it broke at the weld seam nearly causing me to crash and finally their traction kit couldnt fir on my EK. A few of their v8 parts are good but IMO they rushed into the import scene smelling money and making BS race parts that I wouldnt use in my girlfrined's beater.
Old Aug 4, 2003 | 08:21 AM
  #63
Old_Nocturnal's Avatar
Default Re: No love..... (turbotypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotypeR &raquo;</TD></TR><TR><TD CLASS="quote">i found that on the moroso panif you have the oil level up pretty high, it will smoke.if you take the fitting loose from the oil pan you will notice the oil level is above the fitting.i started running a lower oil level and it quit smoking.the pan holds an extra quart so a lower oil level would be no problem.i usually run mine just below the lower dot on the stick.
also,you should run a restrictor on you oil feed line.take the fitting going in the turbo ,weld it up and drill a small hole in the fitting to restrict the flow to the turbo.alot of people use a 4an line for the feed and you do not need that much.</TD></TR></TABLE>
Hmm.. Look, there's the answer to the problem a page and a half ago... Looks like the answer got buried by all of the bs all of the bench racers think they need to throw in
Old Aug 4, 2003 | 12:50 PM
  #64
Default Re: No love..... (Nocturnal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nocturnal &raquo;</TD></TR><TR><TD CLASS="quote">
Hmm.. Look, there's the answer to the problem a page and a half ago... Looks like the answer got buried by all of the bs all of the bench racers think they need to throw in </TD></TR></TABLE>
Actual it is these bench racers that have helped and will continue to help people. Tons of people read these threads and solve their own problems by using troubleshooting ideas from everyone. I assumed the pan was cool because moroso said so. That is why I asked for more input.
Old Aug 4, 2003 | 01:12 PM
  #65
krazy's Avatar
Actual it is these bench racers that have helped and will continue to help people. Tons of people read these threads and solve their own problems by using troubleshooting ideas from everyone. I assumed the pan was cool because moroso said so. That is why I asked for more input.</TD></TR></TABLE>
yea i think everyone was trying to help. even the most experienced tuners need advice once in while right? thanks for backing us up...
krazy
Old Aug 4, 2003 | 01:18 PM
  #66
Bnjmn's Avatar
Was that 4.1 quarts on an empty/rebuilt engine or was that after an oil change?
Thanks
Ben
Old Aug 4, 2003 | 02:34 PM
  #67
Default Re: No love..... (Bnjmn)
Welll....here is how it went. I had 5 quarts into it total. I drained it out and measured it and that is what I came up with after all was said and done. So 4 quarts +- alittle.
J
Old Aug 8, 2003 | 04:03 AM
  #68
Evil DOHC's Avatar
Blown90Hatch,
Sorry I didnt allaborate on what I said. Just get a stock pan and get it tapped where you want to position the return to the best ability you can. Motormatrix is right, when using fittings you are not really getting a true -10 return into your pan. I hate moroso, because all their pan does is look pretty. My friend had one long time and all it did is give him trouble after spending money on a oil pickup, studs, new gaskets, hondabond, etc. Finally he gave up and put a stock pan on his 500 hp daily driven car. His turbo also sits relatively low but he just has a -10 line going straight from the turbo into the pan. Its worth selling that moroso and going stock, the last thing you want is a blown turbo on your hands over a pos moroso pan.
EVIL
Old Aug 8, 2003 | 06:35 AM
  #69
Default Re: No love..... (Evil DOHC)
Evil, yeah I was pretty pissed about the whole pan issue. I bought the pan thinking lighter weight, more oil capacity and a fitting already welded on. It seems to be working right now so we will see. I dyno the car today on pump gas.
90blackcrx
Nov 9, 2009 07:48 AM
NVturbo
Mar 16, 2005 05:33 PM
nonvtecD
Dec 31, 2004 09:30 PM
project dc2
Dec 17, 2004 07:59 PM
MikeyD98
Sep 29, 2004 05:16 PM
