No ground wire to engine, problems arise?
Old Oct 22, 2005 | 03:37 AM
steelies's Avatar
Default No ground wire to engine, problems arise?
I recently had my engine rebuilt, and in teh mix, we forgot to get a ground wire (teh one from the front of the head to the front bumper).
I hadn't noticed until recently that it was missing. And I've been having problems w/ the idle. Didn't know if this could be the cause, or at least part of it. Maybe you guys can give me some direction.
As stated, I don't have the ground wire, keep that in mind. On cold start ups the engine will start, and idle fairly high as expected. However, after idling like such for say 2 or 3 minutes, the engine will just die. And if I turn the headlights on right after start up, it will die immediately.
And lastly, if I get it into any boost before it's operating temprature, the car will pretty much instantly die after I let out of it.
Would all 3 of these problems be related to or an issue b/c of no ground wire? Or am I way off base?
Thanks for any help, as I've been trying to figure this out for a good month or so now.
Old Oct 22, 2005 | 06:33 AM
wade's Avatar
Default Re: No ground wire to engine, problems arise? (steelies)
not to be a smartass, but instead of going months wit wondering, get a wire, 45 seconds and see if it works
Old Oct 22, 2005 | 06:34 AM
DaveF's Avatar
id say that could be a "part" of your problem. many of the sensors, use the engine as a ground. and if your engine/trans isnt properly grounded, it will "throw off" your sensors.. id think if that was your problem, you would be getting all kinds of engine codes/cel's.
Old Oct 22, 2005 | 06:54 AM
m R g S r's Avatar
Default Re: No ground wire to engine, problems arise? (Dturbocivic)
not only is it bad not to have A ground...but you should really upgrade the factory grounds.
I have 3 going to my engine. and don't forget to sand all contact points
Old Oct 22, 2005 | 06:55 AM
shyboy817's Avatar
you have 3 ground wires going to your engine? is that really necessary..sounds like overkill. i'd think one thick 4gauge is enough..
Old Oct 22, 2005 | 09:10 AM
rpm11's Avatar
Default Re: No ground wire to engine, problems arise? (wade)
+1
Old Oct 22, 2005 | 09:22 AM
wade's Avatar
Default Re: No ground wire to engine, problems arise? (rpm11)
+1 to you RPM, heh
Old Oct 23, 2005 | 11:54 AM
Jcup315's Avatar
Default Re: No ground wire to engine, problems arise? (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">not only is it bad not to have A ground...but you should really upgrade the factory grounds.
I have 3 going to my engine. and don't forget to sand all contact points</TD></TR></TABLE>
by upgrade you mean thicker coils? ...and can you tell a pretty big difference having three, b/c if its an improvement I'm all about it.
ramzan_anwar
Nov 28, 2012 07:36 PM
Dwalker
Feb 10, 2008 06:41 PM
trianglegreg
Nov 21, 2006 05:56 PM
E36 Guy
11
Jan 19, 2005 07:18 AM
