Banjo Downpipe?
Old Jun 6, 2004 | 11:43 PM
Stu's Avatar
Stu
New User
Default Banjo Downpipe?
So I was browsing through one of my turbocharger books Turbochargers by Hugh MacInnes (an older book, talks a lot about carbuerators and stuff). Anyway, I noticed in the exhaust section that he talks about Banjo style downpipes. Basically the idea is that if you don't have enough room to fit a properly sized bend onto the turbine housing, you can make a downpipe that looks like a banjo fitting for a water hose or something. He has a picture of some 360cid Buik motor with this set-up. It's really interesting because instead of a big fat elbow, there is a banjo fitting that is only as wide as the turbine housing itself.
I did a little searching and didn't see anything about this one here. Anyway, I was wondering why no one has tried this method for the guys who want to keep their A/C. I'll try to find you a diagram or a picture or something, but I thought it was worth discussing in here. Anyone know what I'm talking about here?
Old Jun 7, 2004 | 12:40 AM
Stu's Avatar
Stu
New User
Well, I did a quick Google search and this was the only result I could find. There are no pictures, but these Mazda 323 guys are talking about the same thing.
http://66.102.7.104/search?q=c...hl=en
Old Jun 7, 2004 | 07:58 AM
Stu's Avatar
Stu
New User
So no one has any inkling of an idea of what I'm talking about here?
Old Jun 7, 2004 | 08:58 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: (Stu)
I saw a down pipe with some thing like that the other day on here. It was like a small rectangel box with a v-band on the side that then turned into the downpipe. I will look for it again
Old Jun 7, 2004 | 12:54 PM
Stu's Avatar
Stu
New User
Default Re: (si2die4)
I've seen that as well. This is a little differnt though. Think of a downpipe that connects with a V band, but is the same size as the turbine housing, you know, like a banjo fitting. I think the reason that this works is because there is enough space to keep flow decent, but I'm not positive, which is why I'm asking here.
Old Jun 7, 2004 | 01:09 PM
-Trinitron-'s Avatar
seems lke it would work...just wouldn't flow very well I wouldn't think. But if you can do a 3-3.5" banjo fitting it would have to flow better than say a 2.5 conventional downpipe...
Old Jun 7, 2004 | 02:36 PM
gritsak's Avatar
Default Re: (-TRINiTRON-)
i think it would have horrible flow..i definitely wouldnt want it on a turbo car...even if its a 3"+ banjo the air coming out of the turbo is still going to basically run into a wall then get pushed out..i think it will cause alot of unwanted backpressure....you can always get exhausts to fit with the right setup (manifold, turbo, ect)
Old Jun 7, 2004 | 03:33 PM
Stu's Avatar
Stu
New User
Default Re: (gritsak)
Well, is there anyone that actually knows anything about them? I mean, they aren't very common, so they can't flow better than a standard downpipe, but I'm just curious how close they are.
Old Jun 7, 2004 | 04:25 PM
gritsak's Avatar
Default Re: (Stu)
no one knows anything about them because no one uses them..that should tell you something right there...with as much hassle as people go through to have turbo with a/c and p/s..if this was a good option it would have been used before
what exactly is it that you want to know about them?
Old Jun 7, 2004 | 06:41 PM
Stu's Avatar
Stu
New User
They've obviously been used before, or else they wouldn't exist. I realize that they aren't as good as a regular downpipe, BUT, in cases where you just CAN NOT fit a regular downpipe there, I want to know how well the stack up.
I thought it'd be obvious that it'd be much easier (and more comfortable) to just use a banjo style downpipe, than it would be to start removing creature comforts.
Old Jun 11, 2004 | 07:52 AM
i my honda
Global Mod
Default Re: (Stu)
Here is the pic I found of what I was talking about (you have to select it, 2nd one over from the left on the bottom)
http://www.attituderacing.com/MariosPage.html
And here is the post about the guy selling it. I really think it would work fine. Just my .02$ though. https://honda-tech.com/zerothread?id=870647
Hope this helps
Old Jun 11, 2004 | 08:49 AM
gritsak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si2die4 &raquo;</TD></TR><TR><TD CLASS="quote">Here is the pic I found of what I was talking about (you have to select it, 2nd one over from the left on the bottom)
Hope this helps </TD></TR></TABLE>
whats that use, a v-band?....if thats what hes talking about using, i wouldnt consider it a banjo..works nothing like banjo fittings for water/oil lines
Old Jun 11, 2004 | 09:28 AM
Stu's Avatar
Stu
New User
Thanks for the post, I've seen that before, but that's not really what I'm talking about. It's literally like a banjo fitting. Think of it as having the top of the DP be shaped like a hollowed out turbine housing, that's what they look like. However, it is the same idea as the picture you linked to. Thanks for the effort.
boostedb20z
Welding / Fabrication
16
Jan 25, 2013 04:16 PM
that-guy
Dec 29, 2010 10:15 AM
Stinkycheezmonky
Apr 26, 2010 05:07 PM
BB6-213
58
Feb 28, 2008 04:24 AM
mrbsponge
Sep 16, 2005 03:53 PM
