Nitrous questions
Old Dec 6, 2003 | 04:28 PM
dynamicauto's Avatar
Default Nitrous questions
I'm building a 'budget' street car, using a d16z6. as far as bottom end, im using JE 12.5:1 pistons, eagle h-beam rods, and getting the crank knifeedged and micro polished. up top, im porting the head, polishing the exhaust side, gasket matching, porting the intake mani and t/b. custom zex cam (havnt decided on specs yet) and full zex valvetrain. Im going to spray a 200 shot of nitrous through a direct port system, probably using an enrichment kit with 112 octane for the juice. I dont forsee fuel being a problem, but can anyone else think of something im missing?
Old Dec 6, 2003 | 08:11 PM
Default Re: Nitrous questions (dynamicauto)
any help? im ready to order the pistons now, so i want to know if im making a mistake.
Old Dec 6, 2003 | 08:15 PM
Jared's Avatar
Sounds like a nice setup. And I'd run VP C16 for the fuel.
Old Dec 6, 2003 | 08:18 PM
t04ecvc's Avatar
Wow, "street" car with 12.5:1 CR and 200 shot and race fuel. Sweeeeeeet!
Old Dec 6, 2003 | 08:21 PM
well street as far as tires i guess... and street as far as fuel run on the street when you said use the c16, you meant in the enrichment tank, eh?
Old Dec 6, 2003 | 08:22 PM
t04ecvc: how did you become a 'non trial user?' i thought it was according to post count, but i see you have less than i, so i was curious..
also, speaking of injectors, (since im new to aftermarket injectors), should i use peak hold or saturated style? also, for the amount of motor im building, what size would you suggest? im thinking 550?
thanks again, in advance.
Modified by dynamicauto at 9:33 PM 12/6/2003
Old Dec 7, 2003 | 05:25 PM
anyone else?
Old Dec 7, 2003 | 05:29 PM
SKDRCR's Avatar
Default Re: (dynamicauto)
if you are running 12:5.1 compression
AND a 200 shot, you better be gettin
some good fuel tuning
Old Dec 7, 2003 | 05:31 PM
oh, of course...
Old Dec 7, 2003 | 05:37 PM
t04ecvc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dynamicauto &raquo;</TD></TR><TR><TD CLASS="quote">t04ecvc: how did you become a 'non trial user?' i thought it was according to post count, but i see you have less than i, so i was curious..
Modified by dynamicauto at 9:33 PM 12/6/2003</TD></TR></TABLE>
You aren't a trial user either. Anyway, with the injector question, it depends on what size you are running.
jamescb77
Apr 1, 2007 10:25 PM
oianarchy
Dec 11, 2006 07:09 AM
viprcr1
Jan 27, 2004 11:29 AM
TodaEK9
Oct 7, 2002 04:44 AM
newsense
Oct 16, 2001 07:47 PM
