NItrous Oxide question
Old Nov 10, 2003 | 06:14 PM
Soccerking3000's Avatar
Default NItrous Oxide question
okay sry if this doesn't pertain to this section but what is the differnce between, a normal nitrous oxide system and a nitrous oxide cheater system???
Old Nov 10, 2003 | 06:17 PM
bottlefedb18c1's Avatar
Default Re: NItrous Oxide question (Soccerking3000)
to what i believe the cheaper is only a little bit and you have to jet or tune your car a bit richer because it don't add fuel only n2o
and with a reg n2o kit you add n20 and fuel unless you are using a dry kit that rises the fp and thus injecting more fuel with the n2o
correct me if i am wrong
Old Nov 10, 2003 | 07:19 PM
Jeff33S's Avatar
If by cheater kit you mean the NOS cheater system read here http://www.holley.com/HiOctn/P....html
The main difference I would say is just that instead of drilling or tapping the Intake Manifold you install a plate... I'm not sure if this is what you are looking for the closest thing NOS makes comparible to their cheater kit for honda's is the GSR (and limited supply of H22) plate kits that remove the butterfly assembly.....
-Jeff-
butter99
Dec 10, 2006 02:08 PM
PreludePhill
Jan 28, 2004 10:19 PM
v-tec crx
13
Dec 26, 2001 06:19 AM
redteg1
Dec 5, 2001 02:18 AM
