nitrous b16a safe?
Old Apr 27, 2004 | 05:57 PM
T l2acer's Avatar
Default nitrous b16a safe?
I am probably going to purchase a zex dry kit for my 92-95 Eg9 b16a. I know people recommend getting a new MSD ignition and fuel pump etc, but i was wondering if the stock fuel pump and ignition would be fine for a 75 shot of nitrous. I know that zex sells a fuel pump upgrade, but i was wondering if running a 75 shot nitrous on a stock b16a w/ intake and greddy evo exuast be safe and would not blow up or is it neccesary to buy the upgrades etc. so the engine wont blow ? I've read that running a 75 shot on a stock b16a will work fine, but my dad seems to think it will blow up. thanks..........sorry if any of this is worded wierd
Old Apr 27, 2004 | 06:11 PM
T l2acer's Avatar
Default Re: nitrous b16a safe? (T l2acer)
and what would be a good size fuel pump?
Old Apr 28, 2004 | 12:28 AM
f1 vtec's Avatar
i just been running 65 shot nitrous on my b16a2 EG9 it worked fine, just make sure u got some decent spark plugs lolz not the zex ones !!!!
Old Apr 28, 2004 | 08:25 AM
yaaj1320's Avatar
just make sure u retard timing like 2 degrees and put colder plugs in it...gaped to .030...and like a 190lph fuel pump and u should be fine...sprak plug.(ngk...bcpr6e-11-s)<-------those r colder plugs for honda civics...zex plugs isn't to good...my friend blew his car using those..
Old Apr 29, 2004 | 12:40 PM
T l2acer's Avatar
Default Re: nitrous b16a safe? (yaaj1320)
To retard my timing all i need is a retard module and selecter and it will hook up to my ignition i have now?
Old Apr 29, 2004 | 12:47 PM
T l2acer's Avatar
or do i need a msd ignition
Old Apr 29, 2004 | 02:01 PM
reactiondc2's Avatar
i ran a 75 shot on my gen 2 j spec b16 and it had a gsr head on it(uped compression) with a stock cx fuel pump and stock timing with no problems for like two years(then i went turbo) so i think you will be fine
Old Apr 29, 2004 | 07:37 PM
T l2acer's Avatar
Default Re: nitrous b16a safe? (reactiondc2)
im ordering the new spark plugs and fuel pump tomorrow along with the zex kit. Thanks alot for your help. When you retard the timing to 2 degrees will my car run fine even when i am not using the nitrous, like in daily driving ?
Old Apr 29, 2004 | 08:14 PM
AzCivic1.6's Avatar
you'll lose a little power with the timing retarded all the time, thats why most get something like the msd digital 6, it'll retard the timing only when the nitrous is spraying, among other things. i just got mine, cant wait to install it.
Old Apr 29, 2004 | 08:54 PM
yaaj1320's Avatar
all i have to say is that....i would retard timing if i didn't have a msd to do the retard for me...i mean u rather b safe than sorry right?..
Old Apr 30, 2004 | 12:54 PM
T l2acer's Avatar
yah , thanks guys
Old Apr 30, 2004 | 12:56 PM
slipslap's Avatar
Get an NOS or NX or Compu Car wet kit. So much easier to install and I feel safer with mine. I know I am adding the needed fuel. So no running lean.
Old Apr 30, 2004 | 04:42 PM
AzCivic1.6's Avatar
zex has a wet kit too. although something about spraying gasoline through my intake doesnt sound to appealing.
DirectPortEF
May 18, 2006 05:51 AM
f1 vtec
Oct 4, 2004 01:21 PM
T l2acer
Apr 27, 2004 05:56 PM
NAcivicEK
Apr 29, 2003 04:09 PM
SpeednSol
15
Feb 22, 2003 04:23 PM
