Nitrious Question may be stupid!!!!!!!
Old Sep 10, 2003 | 07:19 AM
B18c1turboedEK's Avatar
Default Nitrious Question may be stupid!!!!!!!
Ok i know this is probly stupid question,,, while running my intercooler piping i had to take my horn out. So i start thinking couldnt i use those wires to activate my nitrous solends... And i can have them as a button on my sterrring wheel.. I know ill probly be flames but just curious to know.. I hate running wires thru my car so i was thinking of using thee wires!!!!
What u guys think????
Flame suit on
Old Sep 10, 2003 | 07:44 AM
Swift's Avatar
Default Re: Nitrious Question may be stupid!!!!!!! (Koticcivic4u)
Sounds interesting. I dont see why you couldnt do it. Are you actually going to use the horn button to activate the selinoids though or just use the wiring? If so, when ever someone happens to cut you off, dont honk your horn.
Old Sep 10, 2003 | 09:01 AM
spooler's Avatar
make sure you use a switched 12v for the power on the solenoid and it should work. the horn button should just provide the ground for the solenoid. Also use a arming switch.
Old Sep 10, 2003 | 10:39 AM
redlinegsr's Avatar
Default Re: (spooler)
Great idea...let me know how it turns out....im not sure but you might have to check the relay and see the power or "amp" output from it. i dont think y ou can just cut the horn wires and directly wire it to a solenoid
Old Sep 10, 2003 | 10:47 AM
lazerus's Avatar
Default Re: (redlinegsr)
you can easily use it.
We set this up on a friends vehicle with a switch so that standard horn functionality is still retained. flip the switch.. *beep beep!* flip it again... Bwaaaa Bwaaa!
haha.
Brad
Old Apr 28, 2009 | 08:03 PM
chicago8's Avatar
ok what if my painter took all my wires out? wht color wire is the horn button? were can i find it at?
this is on a eg though? and what solenoids get wired? both or just one?
Old Apr 28, 2009 | 11:12 PM
Transpoquick's Avatar
Hey, you live in turbo land......... be careful Bwahahahaahaah
cdscivic
Engine Management and Tuning
12
Feb 24, 2010 03:03 PM
Mikal92
Audio / Security / Video
Sep 12, 2009 12:40 PM
Mike"IAMSLOW"Myers
Nov 26, 2007 06:57 AM
FastNFurious
Jun 14, 2003 06:42 AM
92civicsi
Apr 12, 2003 09:20 PM
