Killswitch
Old Sep 10, 2009 | 07:21 PM
Mikal92's Avatar
Default Killswitch
Do you think I will be able to use on of these as a kill switch and mount it outside the car and would I be able to find it at my local auto parts shop. thanks
http://cgi.ebay.com/2-Wire-Ignition-...#ht_1257wt_935
Old Sep 11, 2009 | 04:37 AM
jason0123's Avatar
Default Re: Killswitch
you should be able to use it as a kill switch for the starter but you will need a relay. those wires look to thin to run alot of current through
Old Sep 11, 2009 | 09:41 PM
Mikal92's Avatar
Do you think I can use a three wired one and cut off one of the wires or ground it.
Old Sep 12, 2009 | 12:40 PM
jason0123's Avatar
no you want to use the 2 leads that are common when in accessory position and use a relay. I can tell you what wires go where if you need.
gitarman2
Jun 28, 2013 05:49 PM
Sound Streamin'
Sep 26, 2011 11:02 AM
95ludeSE_bottle
Jan 13, 2009 06:44 AM
socalrex88
Mar 2, 2008 05:31 PM
