nisssan t3?
hello i wounder that, what is the 80's nissan t3 turbo psi range? is it a good idea to install it in honda dohc zc? i might go silver fmu and around 6-10 psi please please let me know would i be able to get aroung 200whp? if not then what i can do to get that? thanks i am low in budget. thanks i will apperciate some commentssssss
dude you need to do some research before you go turboing a car....you will blow it up for sure, take some time read, learn, then ask questions that actually make somewhat sense.....
I run a garrett t3 super 60 and afc hack with 450's on a sohc d16 @ 6psi i put down 205whp...but that might not happen for you, to many variables...
http://www.homemadeturbo.com is the answer for you, so many setups on there with exactly what you want to do...check em out, take the time and read....yur motor will love you for it
PWRVTEC
Oct 9, 2002 12:05 PM
