New Turbo set-up
Old Dec 5, 2011 | 11:59 AM
la001268's Avatar
Default New Turbo set-up
Hey, what's up honda-tech I have a fully built set up already. It was used for all motor was going to to spray but not a big fan of it. Now I want to boost it.
Well this is a video of the turbo kit on the car
http://www.b20vtec.com/forums/redire...725bdcb1762145
Set up consist of
84.5 gsr block eagle sleeves
11:5 comp wesico piston
Eagle rods with big bolts
Type r water pump and oil pump
Head
Gsr stock port and polish
Crower spring and retainers
With pro 1 cams(had other cams)
Custom intake manifold
Wilson 70mm tb
Fuel would be e85 on low boost and c16 on high boost
I have 1000cc bosch inj
Running a1000 aeromotive fuel pump with the fpr
Chris Miller will be tuning the car since he's been doing he tuning on the motor all resdy
The turbo kit was a custom one that tempest racing did. Turbo is a t3 35r
My brother did 663 at 25 psi on another set up we had.
What do you think Honda-tech
Old Dec 5, 2011 | 12:06 PM
Charlie Moua's Avatar
Default Re: New Turbo set-up
you'll want lower compression if your looking to get anywhere near your brothers power output..
Old Dec 5, 2011 | 12:13 PM
la001268's Avatar
Yea I was thinking of putting a thicker head gasket. I did not want to rip the motor apart and switch the pistons that's my last option but I mIght have to.
Old Dec 5, 2011 | 12:21 PM
well even with a thicker HG, you'd probably only be able to bring it down to 10.1-10.5 range and with that I would not go higher than say 15-17psi on E85.... 84mm gsr with a nice gt35 turbo at 15psi you should see well over 400whp with pro1 cams
GL
Old Dec 5, 2011 | 12:33 PM
TheShodan's Avatar
Moderator
GL
Meh, let the dyno figure it out.
Old Dec 5, 2011 | 02:31 PM
la001268's Avatar
Should I just rip it apart and go with a lower comp
Old Dec 5, 2011 | 02:36 PM
sweetbbyrays's Avatar
sounds pretty shweet
Old Dec 5, 2011 | 03:32 PM
SPOOLINmatt's Avatar
no, you are wrong. thanks.
Do NOT lower that compression. Make as much power as you can or want with that turbo assuming you are going to use race gas or E85.
PM me if you want details on experience, not a bunch of people reading to much honda-tech engine theory 101
Old Dec 5, 2011 | 04:07 PM
yeah sorry i have less experiance than you.
the highest cr i've seen hit 600whp on pump e85 is 10.1
i'm sure others have done it with +11cr... but I can only know what i've seen first hand and talking to the tuner.
Cheers
Old Dec 5, 2011 | 04:16 PM
JDM809's Avatar
plenty of motors on high compression out there making great power. bigger turbos love higher compression. i myself am doing a 81.5mm motor with 10:1 and regret not going with the 11:1 or 11.5:1 pistons now that i decided to go with a bigger turbo (s400 67mm) instead of the turbo i originally had ordered (precision 6262)
Old Dec 5, 2011 | 04:24 PM
sanman000719's Avatar
agreed leave it alone and start tuning
Old Dec 5, 2011 | 05:44 PM
nealnanoHX's Avatar
Yeah i would leave the compression where it is and boost around 10-15psi and get a good tune with good fuel. High compression with boost makes a very responsive motor with good spool up. Again a good tune is a must as higher compression boosted motor walks a thinner line with detention.
Old Dec 5, 2011 | 05:53 PM
and with e85 the det isnt really a factor like with gas
Old Dec 5, 2011 | 05:54 PM
whats all this 10-15 psi talk? make what you want power wise, or what your setup can handle. don't limit boost unless the fuel cant take it or you are just content with medium power. I don't now what the "application" is so i can't bust your ***** lol.
Old Dec 6, 2011 | 11:26 AM
la001268's Avatar
Thanks for the feed back also I will pm you
Old Dec 6, 2011 | 11:32 AM
phat00civic's Avatar
Just watch the AFR but tune away. Typically with a high comp motor the turbo will spin right up, but the motor will lean out that is depending on the fuel used. Use meth and watch what occurs :-) E85 is a good alternative though and great suggestion.
Old Jan 1, 2012 | 01:50 PM
la001268's Avatar
Video up on turbo kit on car, next week it would get tuned
allmotor-teg
Mar 6, 2014 10:23 AM
la001268
Jun 23, 2012 03:40 AM
Dave_Dc2
Apr 21, 2009 03:29 AM
bjones
Dec 15, 2008 02:32 PM
