New turbine housing, compatible with my turbine wheel?
I bought my turbo from a rebuilder (usedturbos.net)
When purchased, It was listed a precision 4431e
(link for turbo info)
http://www.cimotorsports.net/motor-s...bocharger.html
I measured my exducer and inducer.
Inducer : 2.502" (63.5mm)
exducer : 2.17" (55mm)
According to this picture, the stage 3 t31 housing is :
(which I believe my housing is)
Inducer : 64.99mm
exducer : 56.61mm
Anyways. I found a t31 .63 housing. It is a true garret housing which I saw pictures of. It came off a 60 trim turbo. I want to know if this housing will work or not. The guy even said he would let me return it to him if it didn't work out. I am going to re-measure my wheels to confirm my measurements are correct.
Any info will be appreciated.
Inducer : 64.99mm
exducer : 56.61mm
Who is Mr Robot?
Re: New turbine housing, compatible with my turbine wheel?
Your wheel is too small for the housing
Precision doesn't use Garrett at all anymore as Garrett pulled their product contract
TheShodan can chime in with more detailed info
But the only way to get the right housing will probably be from them
ugh..
thanks.
confirmed measurements. 2.17, 2.52
thanks.
underpressure02
02-10-2004 07:26 AM
