New turbine housing, compatible with my turbine wheel?
I bought my turbo from a rebuilder (usedturbos.net)
When purchased, It was listed a precision 4431e (link for turbo info) http://www.cimotorsports.net/motor-s...bocharger.html I measured my exducer and inducer. Inducer : 2.502" (63.5mm) exducer : 2.17" (55mm) https://honda-tech.com/attachment.ph...1&d=1303582957 According to this picture, the stage 3 t31 housing is : (which I believe my housing is) Inducer : 64.99mm exducer : 56.61mm Anyways. I found a t31 .63 housing. It is a true garret housing which I saw pictures of. It came off a 60 trim turbo. I want to know if this housing will work or not. The guy even said he would let me return it to him if it didn't work out. I am going to re-measure my wheels to confirm my measurements are correct. Any info will be appreciated. |
Re: New turbine housing, compatible with my turbine wheel?
Your wheel is too small for the housing
Precision doesn't use Garrett at all anymore as Garrett pulled their product contract TheShodan can chime in with more detailed info But the only way to get the right housing will probably be from them |
ugh..
thanks. confirmed measurements. 2.17, 2.52 |
