New setup whcih fuel pump?
Old Jan 24, 2004 | 10:20 AM
integraracer94's Avatar
Default New setup whcih fuel pump?
On my old setup I was pushing about 315 to the ground and I was using a walbro fuel pump. Well I am planning on pushing the boost up to 25 from 15, so my question is: Can I use my fuel pump I have now or do I need to step it up to something else.
Other fuel related aspects of my setup
AEM fuel rail w/ SS lines
720cc inj
aftermarket regulator
Tell me what you think?
Old Jan 25, 2004 | 01:47 PM
civicshowracing65's Avatar
Default Re: New setup whcih fuel pump? (integraracer94)
is 720cc injectors enough for 25 psi? also, are you controlling your fuel with just the aftermarket fpr? if so, you might want to go with a hondata
Old Jan 25, 2004 | 02:10 PM
Kataku2K3's Avatar
Default Re: New setup whcih fuel pump? (civicshowracing65)
On Brian's motor making ~560whp on 24lbs. (900cc injectors) it runs just fine on an intake Walbro or BBK 255lph pump along with a booster up front or somewhere inline... It doesn't look the cleanest but it gets the job done... If you are planning on running aftermarket (stainless) lines forward then an Aeromotive A1000 would also work just fine... Anything over 28lbs we just run Magnaflow pumps, the Pro Star EFI 600 is really overkill as it supports 2000hp+ but it's one of the only pumps rated at 120psi (the Aeromotive is flow rate is only rated at 45psi) but most people don't want to spend ~$1500+ on their fuel system... It sounds cool tho, hehe... Good Luck
Old Jan 25, 2004 | 04:39 PM
Default Re: New setup whcih fuel pump? (Kataku2K3)
I already have the SS lines run and the aftermarket regulator is already on also. I think my duty cycle on the injectors at 15 lbs was only like 55 - 60 %. I am also already using Hondata
So you are saying just run an inline maybe somewhere after the filter? Thanks for the info
Old Jan 27, 2004 | 10:23 AM
Kataku2K3's Avatar
Damn, sorry I've taken so long to get back to you... But yea, that would probably work just fine... I'll try to take a few pics this weekend when I head back home which will hopefully give you a better idea of how we normally route them... Latez
Old Jan 27, 2004 | 05:36 PM
wow that would be great! thanks
turbolsvtecej1
Dec 7, 2012 09:27 PM
Da K00l Aid Mayun
Sep 21, 2005 11:24 AM
ares650
Sep 19, 2005 04:31 AM
cjb80
Jun 15, 2004 12:21 PM
1SlowSi
Mar 1, 2004 08:50 PM
