new setup is finally on!!!!!!!!!
Old Dec 20, 2004 | 07:58 PM
  #76
ATS*Mark's Avatar
OG triple OG
Default Re: (BauleyCivic)
so are you thinking timing?
Old Dec 20, 2004 | 07:59 PM
  #77
ATS*Mark's Avatar
OG triple OG
Default Re: (Hella_JDM)
are you sure the number would be greater with a leak? that doesnt sound right.
  #78
M.A.R.C.'s Avatar
Default Re: (11psiTurboSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 11psiTurboSI &raquo;</TD></TR><TR><TD CLASS="quote">Did you hook up the coolant lines for the GT35R?</TD></TR></TABLE>
one more time folks... it's a Precision GT35E
ie a NON BALL BEARING turbo
to put it into perspective... think SC61, with a GT turbine wheel instead of the Stage 5 monster. the GT35E is rated @ ~600hp at the flywheel a lil less than the standard T3/SC61 which is rated ~620hp at the flywheel
Old Dec 20, 2004 | 08:01 PM
  #79
BauleyCivic's Avatar
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">are you sure the number would be greater with a leak? that doesnt sound right.</TD></TR></TABLE>
I have an AFC, so my vacuum is read in mm/Hg
At idle, it's normally 450ish...after I've blown a charge pipe, it reads in the 600's.
I'd say timing is your issue.
Old Dec 20, 2004 | 08:06 PM
  #80
ATS*Mark's Avatar
OG triple OG
but all that is pre intake.....if i have a vacuum leak it would be from the intake mani , because i took that off....ill have to look at the timing tomorow.
Old Dec 20, 2004 | 08:09 PM
  #81
Tad's Avatar
Tad
yehhh.... timing would do it too.
take a look at your cam timing.
back when I was monkeying with my n/a nonvtec sohc,
I monkeyed with the cam timing alot. it affected idle a HUGE ammount.
just a thought.. and thats all i know so
Old Dec 20, 2004 | 08:12 PM
  #82
ATS*Mark's Avatar
OG triple OG
Default Re: (Tad)
thanks ill look at it tomorow.
Old Dec 21, 2004 | 07:16 AM
  #83
gitwidit's Avatar
Check cam timing, sounds retarded.
Old Dec 21, 2004 | 07:17 AM
  #84
Tinker219's Avatar
Default Re: (GITWIDIT)
youre retarded
Old Dec 21, 2004 | 09:35 AM
  #85
RyanEJ8's Avatar
Default Re: (Tinker219)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tinker219 &raquo;</TD></TR><TR><TD CLASS="quote">youre retarded </TD></TR></TABLE>
LOL!
Nice setup Hella_JDM!
  #86
Tad's Avatar
Tad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GITWIDIT &raquo;</TD></TR><TR><TD CLASS="quote">Check cam timing, sounds retarded.</TD></TR></TABLE>
well fawk! i dunno..
just trying to help
Old Dec 21, 2004 | 12:52 PM
  #87
ATS*Mark's Avatar
OG triple OG
Default Re: (Tad)
it turned out the timing was perfect.....but i forgot to hook my vacuum line up to my BOV....so it was a leak turns out. anyway the car runs good now , i just need a slim fan.
Old Dec 21, 2004 | 12:54 PM
  #88
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">it turned out the timing was perfect.....but i forgot to hook my vacuum line up to my BOV....so it was a leak turns out. anyway the car runs good now , i just need a slim fan.</TD></TR></TABLE>
You're the slowest-working sonuvabitch eVaR
Old Dec 21, 2004 | 01:46 PM
  #89
Boltz's Avatar
with higher boost its totally different trust me , at lower boost with the greddy kit i felt the same way as you . but higher boost is different.</TD></TR></TABLE>
I still disagree, but am not trying to start a war in your thread. I run about 17.5psi on the street on a SC32 .63 exhaust.
Let us know how it goes....
...When you build the head what are you planning on revving to?
Old Dec 21, 2004 | 02:32 PM
  #90
ATS*Mark's Avatar
OG triple OG
Default Re: (Boltz)
i plan to go to 8500 or so....
Old Dec 21, 2004 | 02:46 PM
  #91
RyanEJ8's Avatar
I have to agree with boltz on that one also. EX gears are way too damn long.
Old Dec 21, 2004 | 02:49 PM
  #92
Tad's Avatar
Tad
Default Re: (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">I have to agree with boltz on that one also. EX gears are way too damn long.</TD></TR></TABLE>
you mean dx gears?
  #93
ELSpool's Avatar
This is the never ending story! I'm still waiting on Hella_JDM to dyno and GITWIDIT to dyno so we can see how the SC-61 and GT35E spool with the little single cam 1.6l's, that way i know which turbo to buy for my new build...
Old Dec 21, 2004 | 03:12 PM
  #94
Danger's Avatar
Default Re: (ELSpool)
is it hella running yet ?!?!
Old Dec 21, 2004 | 03:15 PM
  #95
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ELSpool &raquo;</TD></TR><TR><TD CLASS="quote">This is the never ending story! I'm still waiting on Hella_JDM to dyno and GITWIDIT to dyno so we can see how the SC-61 and GT35E spool with the little single cam 1.6l's, that way i know which turbo to buy for my new build...</TD></TR></TABLE>
Seriously, hurry that **** up boys!
Old Dec 21, 2004 | 04:24 PM
  #96
ATS*Mark's Avatar
OG triple OG
Default Re: (boostincoupe)
my car doesnt like to spool lol.....
Old Dec 21, 2004 | 05:00 PM
  #97
ladysman's Avatar
Glad you didn't mention my name cause it will probably never happen at this point.
Old Dec 21, 2004 | 05:37 PM
  #98
ATS*Mark's Avatar
OG triple OG
Default Re: (ladysman)
oh god what now!!!
Old Dec 21, 2004 | 06:31 PM
  #99
TheShodan's Avatar
Moderator
GT35E which is a Journal Bearing
Old Dec 21, 2004 | 07:12 PM
  #100
ATS*Mark's Avatar
OG triple OG
Default Re: (TheShodan)
E stands for exciting boost spool y0.
