New pistons and Rods...Break In?
Old Nov 24, 2001 | 02:30 PM
KhRoNiX's Avatar
Default New pistons and Rods...Break In?
Im turboing my GSR and got new pistons and rods. When my car is tuned, it is going to be run hard. Is this bad considering the pistons are brand new. Also what is the break in time for new pistons and rods? TIA
Old Nov 24, 2001 | 03:15 PM
dustin's Avatar
Default Re: New pistons and Rods...Break In? (KhRoNiX)
You are gonna want to break in the new rings for about 1k miles. No high revving, no boost. The 1k miles should be daily driving miles, freeway driving does not count.
Dustin
Old Nov 24, 2001 | 05:44 PM
Eric J's Avatar
Break-in procedure quoted from T.O.O. @ Endyn BBS:
"Use 0-30, or 5-30, or 10-30 motor oil and a Honda filter. Do NOT use synthetic motor oil for break in.
Make sure the fluid levels are where they should be.
Start it up and keep the engine at 2500 -3000 rpm for about 20 minutes. Make sure there are no leaks, or mechanical problems. The only idling will be for setting the timing.
Before doing the schedule, remember that running the engine at steady rpm (like cruising on the freeway) is not good for break-in.
0-200 miles. Try to keep the highest rpm under 3000 rpm. Every 15-20 miles, zing the engine to 4500 rpm in first and occasionally in second gear.
200-400 miles. Try to keep the revs limited to 3500 rpm. Raise the "zing" rpm to 5500 with the same frequency as above.
400-600 miles. Go to 4000 rpm for driving limit. Raise the "zing" to 6000 - 6500 rpm and include 3rd gear pulls, same frequency.
600-800 miles. 4500 rpm driving limit. "Zing" it to 7000+ rpm and include partial 4th gear pulls.
800-1K miles. 5000 rpm limit with "zing" to 7500+ with some pulls all the way through 4th and partial fifth gear pulls.
Now, don't misunderstand me on the zings. You don't HAVE to scream the engine religeously at the prescribed intervals. If you don't have the space to run the engine up in the selected gears, don't do it. Just know that you can, and IF the opportunity comes around lay into it. Don't over-do the procedure.
I recommend that the oil be changed at the 1K mile marker. If the plugs are looking good and if the compression's (and leak down numbers) good, switch to Mobil 1 for life. Use either 0-30, or 10-30.
After the oil change, you might want to reset the valves and from that point on, drive it the way you'd normally run it."
Old Nov 24, 2001 | 06:01 PM
KhRoNiX's Avatar
Ok thanks for the input. Now what about the tuning. My car is going to be tuned as soon as the pistons are put in so the car is going to be run pretty hard on the dyno, Is this bad?
Old Nov 24, 2001 | 06:34 PM
Eric J's Avatar
Did you replace the rings and hone the cylinder bores when you installed the pistons? If you did, then you really shouldn't run it hard (high RPMs or high load) until the rings have fully seated. If you do run it hard right away, there is a good possibility the cylinder walls will glaze and the rings will never seat. This will cause the motor to have bad compression and burn oil like most of the new VWs do
Old Nov 24, 2001 | 09:47 PM
KhRoNiX's Avatar
Default Re: New pistons and Rods...Break In? (Eric J)
Well, the rings were replaced but no honing was done. Should I tell my mechanic to let me put some miles on the car before the dyno?
Old Nov 25, 2001 | 06:42 AM
KhRoNiX's Avatar
TTT
Old Nov 25, 2001 | 07:29 AM
civictom's Avatar
it should of been honed if you're putting new rings in.....you don't want new rings without honing just like you don't want to hone it and put in old rings..the rings just won't seat right.
Old Nov 25, 2001 | 09:14 AM
Eric J's Avatar
Like civictom said, you should always hone the cylinders to provide a new seating surface for new rings. What brand of rings are you using? Depending on the rings used, sometimes you can get away with not honing the cylinders if the motor has low miles on it. What I mean by get away with is they could seat good enough for decent compression numbers and prevent serious oil burning problems. Most likely the compression will be on the low side though.
Old Nov 25, 2001 | 05:45 PM
KhRoNiX's Avatar
Well my mechanic said that because my car is pretty new (20,000 miles) that honing "probably" won't be necessary. Should I tell him otherwise? Also the rings and pistons are both JE (9:1 CR). Should I wait till after the break in period for my car to be tuned? TIA
Old Nov 25, 2001 | 07:19 PM
turboex's Avatar
my motor will be finish next week. i had i bordover .20 and i have 9.1 pistons and eagle rods for the drag3 turbo that destroyed my last set. personall im pulling the turbo of for the fisrt 1,500miles yeah i know this is hard to do but i gotta do the right thing the first time. after that its all gravy!
Old Nov 26, 2001 | 10:21 PM
Eric J's Avatar
Most aftermarket rings will require a much courser honing finish than OEM Honda rings to get them to seat correctly. If the motor is already in the car, then you might as well break the motor in for 1k miles without the turbo on, and then check the compression and leak down numbers to confirm if the rings are seating or not. HTH
Old Nov 26, 2001 | 10:42 PM
SpeedMonkeyRacing's Avatar
yeah..this is something i would like to know too. I'm in the process of rebuilding my motor w/ built top and buttom end..however, I will be on dyno to tune it w/ hondata....i guess i should wait to braek in first before i install hondata?!?
Jeff-
Old Nov 27, 2001 | 08:15 AM
rtype11's Avatar
if you dont have the time for proper break in, put a capfull of ATF in each cylinder via sparkplug hole, and beat the crap out of your car, may help seat rings fast.
Pellegrini808
Sep 29, 2013 11:14 AM
Teamdiesel
15
Nov 8, 2007 07:31 AM
zer0zer0 TypeR
Sep 4, 2003 11:35 AM
craigmk2crx
Jul 15, 2002 02:43 AM
threatcon13
Feb 2, 2002 01:14 AM
