new JRSC LHT and 4k rpm idle at startup
i have been searching for a vacuum leak, but so far nothing.
Here is a video of what is happening. Any JRSC guys that have experienced this before, please shed some light.
The blower is screaming
http://www.youtube.com/watch?v=T9G4_qSpBrc
Changed IACV's but it did not help. 0% TPS and hondata shows -17" of vacuum.
Is it safe to let it idle that high while I spray carb cleaner around to find the leak?
Re: new JRSC LHT and 4k rpm idle at startup
i had the same problem .. there were a few things #1 I checked the tb it had a bad vac leak #2 check the iac and adjusted the screw .. and i still had ideling problems i never could get it corrected it ideled at 900-1k .. try the jrsc thread in the fi section
throttle cable is disconnected
initially its just a high idle, then it starts surging from 1300 to 3000 rpm
try plugging the hole under the throttle body, the one that goes to the pcv valve, recheck all vacum lines and if all else fails, IM gasket might be bad.
JohnnieChimpo
07-15-2007 02:03 PM
