New info on profec b switch.
Old Jul 24, 2003 | 11:27 PM
JM Performance's Avatar
Default New info on profec b switch.
I was playing w/ my profec b today. I'm gunna hook up a switch for high/low boost.
Anyway, I found out that it needs a ground signal, not power. Makes it a little easier.
Thought I'd share this.
Old Jul 24, 2003 | 11:43 PM
MiraiZ's Avatar
Default Re: New info on profec b switch. (00SilverLS)
are you talking about the steering wheel mounted switch?
Old Jul 25, 2003 | 12:50 AM
SiR Kid's Avatar
New User
Default Re: New info on profec b switch. (MiraiZ)
Sweet. Im gunna run a ground wire to mine asap. Put a big "bopit" switch on the dash... 1st, 2nd, BOPIT, 3rd! WOOOOOO!!!! Riiight.
Old Jul 25, 2003 | 06:24 AM
Racerboy03's Avatar
Default Re: New info on profec b switch. (SiR Kid)
What wires do you need to hook up to make your own switch instead of buying it from Greddy?
Old Jul 25, 2003 | 09:08 AM
Default Re: New info on profec b switch. (Racerboy03)
Just any momentary switch to pass a ground signal to the option port using a normal headphones jack.
Sooo simple.
Old Jul 25, 2003 | 10:37 AM
rjardy's Avatar
oh cool, so you just need a momontary switch? I thought that you had to hold it to stay at high boost levels, So its like hit it once= high, hit it again= low boost?
Rob
Old Jul 25, 2003 | 10:48 AM
Pengo's Avatar
Default Re: New info on profec b switch. (rjardy)
i thought it needed voltage to switch. someone here did a write up on his website on it awhile ago. he used his horn button as the switch and lists the relay you'll need from radioshack
B18EG6
Jul 23, 2008 01:03 PM
2ltrsnailpwr
Nov 27, 2003 05:57 AM
speedworks
Aug 14, 2003 09:05 PM
