New catch can design...
Old Aug 23, 2007 | 11:53 AM
seerx's Avatar
Default New catch can design...
Once I get the car running I will post results of how much pressure is still in the crankcase. 6 ports total are feeding into this. All hoses are 3/8. 2 from the drain ports that are drilled and tapped (oil from the head goes threw these ports down to the pan). 3 from the valve cover (2 drilled and tapped in the back of the valve cover and the original port that Honda has baffled). One more from the factory big hole (about 1 inch) in the bottom of this "catch can". That hole also works as a drain. Hope I explained this clear enough. The only thing I am worried about is that the outlet port will not relieve enough pressure. We will see when it is up and running. I want to hear opinions, good and bad. Thanks- Eric
Old Aug 23, 2007 | 11:58 AM
shockerjoe says's Avatar
Default Re: New catch can design... (seerx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seerx &raquo;</TD></TR><TR><TD CLASS="quote">
Old Aug 23, 2007 | 12:18 PM
OLD_HATCH's Avatar
Is that the stock can in the back of the blok you tapped out?
Old Aug 23, 2007 | 12:19 PM
ELSpool's Avatar
I wanna see more pics of that turbo manifold!
Old Aug 23, 2007 | 12:24 PM
seerx's Avatar
Yes that is the stock can. I modified the inside with more baffles and drilled some holes in certain places to let it flow some more. The outlet pipe is staying dry so far(I have less then 50 miles on it) . So the baffles are working . I am just worried its not flowing enough. Need to put a gauge on my dipstick tube and see what happens.
Old Aug 23, 2007 | 02:03 PM
Simmerman's Avatar
Default Re: (ELSpool)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ELSpool &raquo;</TD></TR><TR><TD CLASS="quote">I wanna see more pics of that turbo manifold!</TD></TR></TABLE>
+1. What brand?
Old Aug 23, 2007 | 02:09 PM
Jared's Avatar
so you tapped it out and its still on the back of the block?
Old Aug 23, 2007 | 02:45 PM
EK_vzla's Avatar
-crazy manifold.
-what numbers you have in that engine?
-that its 3" pipes?
Old Aug 23, 2007 | 03:50 PM
raene's Avatar
****... that's almost exactly what I was going to do, except build a larger can and use much larger vents. Good work
Old Aug 23, 2007 | 04:36 PM
Mr HYDE's Avatar
Default Re: New catch can design... (raene)
no intercooler at all? id put a power barrel(air-water) on it.
where are all those ports on the can going?
Old Aug 23, 2007 | 04:37 PM
ferio82's Avatar
Default Re: New catch can design... (Mr HYDE)
nice manifold man , nice setup
Old Aug 23, 2007 | 04:51 PM
cbustuner's Avatar
Thats kinda how rota has his only with one big AN fitting in the middle of the oem black box, and 2 ports off the valve cover last I looked.
Old Aug 23, 2007 | 05:54 PM
Sprockets's Avatar
Looks good. Very unique! I've always wondered what the D series guys do. What's that male -an fitting between the battery and fuel filter connected to?
Old Aug 23, 2007 | 08:22 PM
seerx's Avatar
1.For those who asked the manifold and kit was home made. 2. I will be running a air to water intercooler when it arrives. 3. That -an is a old catch can setup( may run the outlet of my catch can to that, just to use as a filter) and 4. just to clarify the ports come FROM the motor to the can and then out the can to vent . Thanks for all the feedback!
Daffy_ed9
Engine Machining & Assembly
Sep 3, 2018 12:42 PM
Mr.Chow
27
Jan 6, 2012 06:29 PM
92vteclude
Jan 9, 2006 09:42 AM
Sprockets
Jan 3, 2006 07:30 AM
dieselboy
Aug 10, 2001 07:55 AM
