Cracked Valve Cover!!!
Old Aug 9, 2001 | 06:04 PM
dieselboy's Avatar
New User
Default Cracked Valve Cover!!!
Here's a situation that I can't figure out. My 99 Si B16 valve cover has a tiny crack on it and is leaking a little bit of oil. I can't figure out how and why it happened. It doesn't leak much oil, like 1 drop a day. Does that effect my vtec pressure or anything? Should I just leave it alone or change the valve cover. The car runs great and everything. Thanks.
Old Aug 9, 2001 | 06:21 PM
ALF's Avatar
ALF
Default Re: Cracked Valve Cover!!! (dieselboy)
Where exactly is the crack?
Old Aug 9, 2001 | 07:26 PM
fixhondas's Avatar
It has nothing to do with oil pressure- you could clean it and put some Hondabond on it- or you could have someone weld it if you are really concerned- or you could just leave it. I can't stand oil leaks so I would fix it if it were mine.
Old Aug 10, 2001 | 05:19 AM
92sleepR's Avatar
New User
Don't worry about it. just take it off, clean the oil off and put a little JB Weld epoxy on it from the inside. That should take care of it. As to why it cracked in the first place? Who knows, it's not a highly stressed part but assuming that nothing else is visibally wrong with your engine i wouldn't worry about it.
Mike
Old Aug 10, 2001 | 07:55 AM
Misfit's Avatar
Default Re: Cracked Valve Cover!!! (92sleepR)
just spend the money and get a new one.
crxb16sir
17
Dec 16, 2009 12:27 AM
94ls
May 20, 2004 06:49 AM
J337_UNIT
Sep 4, 2003 12:47 PM
