New to boost. Got a few questions.
Old Jul 8, 2012 | 05:01 AM
civic89si666's Avatar
Default New to boost. Got a few questions.
I have a 95 civic hatch with a gsr and a Blackworks racing turbo kit. It has a 50mm Tial blow of valve and a 44 mm wastegate. It also has a 3 inch downpipe to a 2.5 inch exhaust (restictive I know, but I've gotta pass inspection.) My questions are.
-how much vacuum should I have? I currently have 10-12 inhg, butbi have a plain bov spring and in getting crazy amounts of flutter with my bov. Is this amount of vacuum normal? I've heard Hondas should be up near 20 inhg.
-How should I run my vacuum lines for wastegate/bov. I have a wastegate, bov, boost gauge, fuel pressure reg, that all need to be hooked up. Should I just get a vacuum block?
-also, Do I need to hook up a catch can set up ASAP? I know most people do, I'm just on a budget and am saving for a tune.
Any hell is appreciated, thanks guys.
Old Jul 8, 2012 | 06:14 AM
dpetro1's Avatar
Default Re: New to boost. Got a few questions.
1. hondas generally have 20-22" vac at warm idle
2. the bov should have its own dedicated line. wastegates do not need vac lines, just a boost reference
3. how much power are you making? a catch can its absolutely necessary but should be added once you start making higher hp
these topics could have been answered with a quick search
vacuum at idle
https://honda-tech.com/forums/showth...ht=vacuum+idle
vacuum manifold
https://honda-tech.com/forums/showth...hlight=vaccuum
bov routing
https://honda-tech.com/forums/showth...light=bov+line
Old Jul 9, 2012 | 09:44 PM
EsotericImage's Avatar
Retired Moderator
how do u have your boost gauge hooked up?
Old Jul 10, 2012 | 04:57 AM
TheShodan's Avatar
Moderator
Originally Posted by civic89si666
Should I just get a vacuum block? A vacuum block is always a great idea. The fewer the number of "T"s in your vacuum lines (splitters) the better
-also, Do I need to hook up a catch can set up ASAP? I know most people do, I'm just on a budget and am saving for a tune. Not if you power levels are under 400whp. You can still use the stock PCV system. It will perform fine.
Any help is appreciated, thanks guys. Fixed
dcintegra88
Jan 18, 2010 01:42 PM
jdm-ray
May 15, 2005 09:37 PM
Ricey McRicerton
Sep 23, 2003 04:04 AM
01ITR#700
Nov 16, 2002 12:59 PM
_Endless_
Aug 30, 2002 06:30 PM
